[Z06] Katech Carbon Fiber Splitter, Undertray, and Brake Duct PICS and PRE-ORDER
Premium Supporting Vendor
I'm pleased to announce that we have undertrays and brake cooler ducts will be arriving at the end of the month. We've started a pre-order system on our website and will ship in the order received.
These parts turned out great. This week we were in the wind tunnel with the final version to verify the final production. Let me tell you the brake cooling increases are PHENOMENAL! That is reason enough to buy this splitter package. Don't take my word for it, take a look at the pictures of our testing and see for yourself.
You can see when we add the smoke to the entry of the brake cooling duct it starts pouring out the wheel, and this is at only 45mph. This is true ram-air brake cooling. You track guys are going to love this. Combine this with a set of spindle ducts and you have brake cooling that rivals race cars.
Next is the installation. This is so easy! There is no drilling of your new splitter. All you do is remove the stock splitter, remove the air dam and stock brake duct inlet, trim a small part off the bottom of the fascia, install the brake duct, install the splitter, and install the undertray. I'll have detailed instructions soon, but we just put one on in about a half hour.
The brake ducts were solid modeled for a precise fit. Here are some photos of our development.
The fit is perfect. The ducts slide right into the production brake duct. They are made with a mold so the shiny carbon fiber is on the inside. So when you look from the front of the car you can see into the glossy brake duct.
After the splitter and the brake ducts are on, 2 stainless steel brackets hold the rear of the undertray and the front of the undertray attaches to the lip of the splitter. These brackets use factory mounting locations. All stainless steel hardware is included for a nice finish that will last a long time.
The splitter fits all C6 wide body cars - Z06, ZR1 and Grand Sport
Part numbers are as follows:
KAT-A4979 Katech carbon fiber splitter, brake ducts and undertray kit $1774.99
http://store.katechengines.com/Product212
KAT-A6097 Katech carbon fiber brake ducts and undertray kit $1199.99
http://store.katechengines.com/Product211
KAT-4979 Katech carbon fiber splitter (only) $575.00
http://store.katechengines.com/Product193
Jason,
Great looking package!
The ultimate result is making a car safer which should be every drivers goal.
The dollars spent up front now on this package will pay huge dividends going forward towards pad and rotor longevity.
Mike
Mike
Does this significantly increase the overall drag or add to downforce?
Love the look of it; I'm wondering if it wouldn't be a bad idea to put some clearbra protector on the underside so it doesn't get all scratched up on curbs.
You could do the clearbra protector if you want, but I think if you scrape something it's going to scrape right through it. That's more for rock chips. The button head screws on the undertray do offer a bit of protection though.
This is a good, common sense approach to brake cooling.
The tray is rigid, but I can pull down on it and it pulls on the fascia. You could have a steel plate for an undertray and it's still going to pull down on the plastic fascia. That's just my opinion. The car in the wind tunnel test already had the reinforcement, so we couldn't test that. If somebody wants to do 150 without the reinforcement be my guest. The reinforcement is $234.
Ernie O
(I've been well over 160 on some front and rear straights so no need to have issues.)
We stock them, or at least try to but GM can't keep up with my orders. Or you can get them from any forum vendor.
Stock, the Z's don't use any air from below for cooling the radiator, only the regular Vettes do this. If you're turbo'd with intercoolers down there then it looks like you'll need to do some custom fitting.
