C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] DIY Oil Change Jacking tools
Old 02-17-2010, 09:34 PM
0Jon @ Speed Inc
Former Vendor
Jon @ Speed Inc's Avatar
Default DIY Oil Change Jacking tools
(Disclaimer #1 : I don't work out of the Speed Inc shop currently. I'm about 2 hours away from the shop at my current location. If I was still out of the shop I'd just use the lifts there.)
(Disclaimer #2 : I do not trust a dealership to change the oil. Not one bit. I've heard too many stories of oil change techs forcing the cap off of the valve cover.)
This spring I'll need to change my oil. I need to lift the car up and keep it level without dropping a ton of money on a lift or a few super expensive jacks. I've read the threads where people list jack part #'s and setups, but some of those parts are out of date or no longer available.
I just received a northern tool catalog and there was a 3.5" high jack that looks like it will do the part to jack from the center of each of the subframes. $124.99 http://goo.gl/sLkh I'm not sure if this one is "long" enough. I have a feeling it isn't.
I know with the subframes you can't put all the weight right in the middle. I can't find a jack "t" bar in the catalog. I really think a 2x4 would work to disperse the weight. Then use a jack stand at each end of the 2x4, then go to the other side of the car and jack it up.
Any ideas on how to pull this off with one jack safely that doesn't cost $500? I know there is a commonly used on Amazon.com - you just have to catch it when they are offering free shipping.
Old 02-17-2010, 09:36 PM
clogan
clogan's Avatar
I just drive my Z up some 2x10 planks onto Rhino ramps.
EZ
CW
Old 02-17-2010, 10:13 PM
0Jon @ Speed Inc
Former Vendor
EZ
CW
I havn't looked into that (except for the pricey race ramps). The ground clearance is just so low I didn't think it'd work so well.
Old 02-17-2010, 10:43 PM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
Others have done it and I followed their lead...
Jacking from the center is no problem. Here's my set-up...
You want to catch the frame where the seat supports connect to the frame rail. I cut strips of hard rubber to fit right in the area of the frame that I need to jack to have clearance from the rockers and not mark up anything. I also use hockey puck in the 4 corners.
Got the aluminum jack and stands from harbor freight for under $200 total.
Old 02-17-2010, 10:49 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
They are pricey but "ultra" light weight and easy to store. I use them for quick oil changes.
Old 02-18-2010, 03:34 AM
HP ADDICT
HP ADDICT's Avatar
I just use the aluminum race jack from northern tool. Use one puck on the front left to raise the car and slide under the pan. Open the drain plug and lower it back down to drain level. Saves alot of time and money.
Old 02-18-2010, 09:37 AM
DSteck
DSteck's Avatar
+1 for Race Ramps. I bought a set, and they are awesome. I did a header install with them on my buddy's car.
Old 02-18-2010, 10:00 AM
LFZ
LFZ's Avatar
Scott, from this pic..you jacked the center of one side, put in the jack stands at the appropriate locations with pucks, and jacked the center of the other side repeating the same process??? I tried this, but was leary of putting the car on jack stands on one side while the car was at such a sideways angle...know what I mean? (And I didn't have an extra jack to go to the other side either, so it could catch up.)
Old 02-19-2010, 08:01 AM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
AP, the Jack stands remain stable on the first side with the hard rubber pucks sticking to the car like glue while jacking the second side. Make sure the jack is on a relatively smooth surface and is at a 90 from the car to allow it to roll slightly as it is being elevated, compensating for the "tilt" of the car. I've also raised the car higher on the jack stands incrementally using the same method from side to side being careful to go up only one notch per side on the jacks for safety's sake. Also be sure to lower the car in the same manner and you'll have no problem.
PS. Another important note would be the beginning height of you jack stands. Mine are relatively short, maybe 12" with the pucks. I'll check the exact height when I get home and post. Obviously if your jack stands are monsters...that would be bad for this application.
Old 02-19-2010, 10:17 AM
LFZ
LFZ's Avatar
Thanks! I have jackstands that are the same height as yours. I need to pull my wheels and replace the rubber...I will try this method..if it fails...I will make you pay for it with all the money you have.
Old 02-19-2010, 11:13 AM
1badassZ
1badassZ's Avatar
My answer for DIY oil change jack points. $700.00
Please excuse the mess..
Old 02-19-2010, 11:50 AM
0Jon @ Speed Inc
Former Vendor
[/IMG]
Details?
Old 02-19-2010, 11:54 AM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
If it fails, just make sure you're not under it...
Be careful.
Old 02-19-2010, 12:05 PM
1badassZ
1badassZ's Avatar
Details?
craigslist
Old 02-19-2010, 12:12 PM
FNBADAZ06
FNBADAZ06's Avatar
While I don't use this particualr brand, I use a motorcycle/ATV lift to put my car in the air to be able to place jack stands. The jack is pretty low profile and many support weights in excess of 1500 lbs. I place my jack under the front or rear cradles...with the dual contact points, all the weight/pressure is distributed over a wider area.
Old 02-19-2010, 02:13 PM
davidfarmer
davidfarmer's Avatar
3LZZ06's solution is mine as well. I jack center of the frame adjacent to where the seat brace ties in, for added strength. I have a 4"x4" 1x4 that I cut and wrapped with aluminum as a pad to protect the frame.
Jacked the car at least 100 times at home and at the track, and the frame is in fine shape.
Old 02-19-2010, 07:42 PM
Sethbaja23
Sethbaja23's Avatar
Old 02-19-2010, 08:02 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
Here's a follow up to this post...
Got the idea and the "how to" from you David...
To DIY Oil Change Jacking tools
Quick Reply: [Z06] DIY Oil Change Jacking tools
