[Z06] Hatch pull down
Hatch pull down
I just bought an 08 2LZ with 3500 mi, the owners manual says to close the rear hatch and the automatic pull down will close it the rest of the way, that is not what is happening with mine, I have to slam it to close,
is there something I am doing wrong?
You don't even need to drop the hatch with the windows and door shut. I am able to shut it with a gentle push once it is in contact with the locking mechanism.
"Closing the Rear Compartment (Coupe)"
"To assist in closeing the rear compartment lid of your coupe, use the pocket on the underside of the lid, lower it until the power pull down latch feature activates and it will close the rest of the way and latch automatically."
Not that I care and would rather not have the auto pull down feature but does anyone have that feature as an option or part of a higher package?
Wow, on page 2-14 of my 2008 Owners Manual it says
I always open a door before I shut the hatch and it shuts fine....
Also that "(Coupe)" does not mean Z06... thats the standard C6.
CF Senior Member
I find it amazing that GM discontinued the hatch motor for 3 years even though they knew there was an issue with closing the hatch with the windows up.
Gotta save weight.
Right you are! I guess they are refering to the non-Zo6 car.
I had a 2005 coupe with the auto pull down latch. When I got my 2006 Z06 I really missed that feature, as well as the adjustable lumbar support and bolsters.
I installed a pair of seats from a regular C6 to get full power on the passenger side, and the adjustable lumbar/bolsters both sides.
I also installed an auto pull down latch. You can read about it in this thread (you have to scroll down to around post# 44 where I got the parts and finally did the installation):
http://forums.corvetteforum.com/c6-z...ear-hatch.html
Bob
Bob
I have my windows and doors closed most of the time when I'm closing my hatch, so the striker doesn't go deep enough into the latch to lock - it goes in just deep enough to activate the auto pull down feature.
Bob
08 hatch pull down
My owner manual also states that the hatch has a auto pull down. Mine evidently does not but I can close the hatch by pushing down with one finger until the locking mechanism engages. This with the windows up. No need to slam it at all.
FYI - the owners manual covers all models of the Corvette (at least it did in 06) - it is not specific to the Z06. So it will discuss features that are standard in other models but not present in the Z06.
St. Jude Donor '12
this.
The hatch, whether you have auto down or man down, regardless, will close easier with a window open (cracked) or a door open.
I have a '10 and thought it did not work. the key is making sure the door or window open so pressure will not hamper the hatch closing. These cars (cabins) are sealed GOOD for the type of car it is.
Add: also the owners manual will say something like "Z06" models or "LS7" models since the manual covers ALL models.
at its introduction. Other than the alloy frame no one thing saved more than a few pounds, even those expensive carbon fiber fenders. Getting down
to 3132 pounds required deleting things and limiting options. Then after the C6 Z06's fantastic reputation for performance was established (and Dave
Hill retired) more equipment and options were allowed each year.
