[Z06] PS2's on a Z06
PS2's on a Z06
Hi everyone,
I am looking at purchasing a used set of rims and tires and the rear rims are 12 1/2" x 19 with PS2's non run-flats size 345/30/19's. These rims and tires will be going on a 2007 Z06. The car is completely stock at this time and has not been lowered and I am not planning on lowering. Does anyone know if this setup will rub?
Love my PS2Zps. Great improvement in every way over the Goodyears (except more expensive but worth every penny).
I use the 345/30-19 Michelin PS2 tires on OEM Z06 wheels. They do not rub or stick out of the wheelwell. They are an awesome tire.
You really need to look at the wheels and what the offset is to determine if they will fit. They should be as close to OEM as possible.
If not, the tires will fit your OEM wheels.
