C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
View Poll Results: If you have had catastrophic engine failure or a dropped valve: please check one
Stock engine(No Mods) and Stock Tune
52.38%
Stock engine(No Mods) and Tuned
23.81%
Modded Engine(Cam etc.) and Tuned
23.81%
Voters: 21. You may not vote on this poll
[Z06] Poll on LS7's with dropped valves or catastrophic engine failure
Old 06-26-2010, 06:49 PM
Mr. Gizmo
Mr. Gizmo's Avatar
Default Poll on LS7's with dropped valves or catastrophic engine failure
Will be interesting to see the result
Statistics so far as of june 30,2010:
There have been 1082 viewers of this poll as of the moment I write this reply.
There have been 18 engines that have had catastrophic failure.
*This represents about 1.6% engine failure rate assuming all 1082 that viewed the post and of those 1082 those with catastrophic failure actually voted.
There have been 10 of those that are totally stock that have had catastrophic engine failure (No Tune and No Mod)
*This represents slightly less the 1% engine failure rate assuming all 1082 that viewed the post and of those 1082 those with catastrophic failure voted.
*It seems a tune has no impact on engine failure as there are more failures on stock tunes then there are tuned motors - this statement would assume half the viewers of the poll have tunes and half still remain with the stock tune.
1% engine failure rate or 1 in 100 - seems pretty high.
This should make the folks from GM that monitor our forum take notice.
Old 06-26-2010, 07:29 PM
HP ADDICT
HP ADDICT's Avatar
Think you add a stock with no problem or modded with no problems option to at least add perspective to this poll.
Old 06-26-2010, 08:10 PM
1stZ
1stZ's Avatar
Option to those who blew up their engine more than once? I only voted once. I'm planning/saving for my 3rd motor. Lost my 2nd motor 2 weeks ago. FYI, my 2nd motor was built with durability (most moving parts are forged) in mind but still lost it due to the snapped exhaust valve (forge stainless steel exhaust valve). 1st motor lasted 17k miles (13k of the 17k miles was stock with only tune & KB CAI; 4k miles with lg cam & headers added bolt on) with ~35-40 track days (rr). 2nd motor only lasted 20k miles, ~18 track days & a handful of high speed runs (160-190+ mph runs). 2nd motor built with forged pistons, stock crank, are dry sump, stainless solid steel exhaust valve, crowler rocker arms, etc... Too much to list. I'm convinced base soley on my own experience & no one else that exhaust valves seems to be are the parts that I consider the weak link.
Old 06-26-2010, 09:38 PM
Mr. Gizmo
Mr. Gizmo's Avatar
for 2 motors it was exhaust valve that gave way both times? did you have the hollow sodium filled on both failures?
GM tech i have spoken to, says every ls7 that he has seen that comes in thats blown apart has a tune, if you leave the tune alone, he says these motors will last forever. This guy is a hot rodder - has a 2005 c6 with a blower on it.
The poll so far has stock engine no mods and stock tune blowing up 2 to 1 over modded or tuned LS7's.
Old 06-26-2010, 10:08 PM
Jasil
Jasil's Avatar
So 1st Z you think it's the exhaust valve and you've had both fail? SS and sodium filled?
Old 06-26-2010, 10:23 PM
jimman
jimman's Avatar
You left out probably the most significant fault mechanism, early down shift resulting in over rev. Unfortunately few will admit to that.
Old 06-26-2010, 10:55 PM
BSSN
BSSN's Avatar
I think a "no problems" option should have been included.
Mr. Gizmo
Mr. Gizmo's Avatar
Of course that does not count - user error
Old 06-26-2010, 10:58 PM
Mr. Gizmo
Mr. Gizmo's Avatar
Of course no problems will overwhelmingly outweigh catastrophic failure and thats not the intent of the poll.
The point of the poll is to look at only those LS7's that have come apart, and then look at mods, tune, versus completely stock.
So far the stock no tune cars are blowing apart more then the tuned or modded cars.
Old 06-26-2010, 11:08 PM
zoomz
zoomz's Avatar
Does model year have anything to do with it or is it ALL 427's ?
I would be interested to know if its a certain year or years .
I just bought an 06 .
Old 06-26-2010, 11:13 PM
Mr. Gizmo
Mr. Gizmo's Avatar
'07s had a known problem, those produced before march of 07.
I guess you can look at the profiles of those that answered the poll and see what year Z they have.
Old 06-26-2010, 11:53 PM
BSSN
BSSN's Avatar
If 10 people say their motors have gone TU and 3500 others say "no problem", it would tell us quite a good bit I think. Shi*t happens.
However, 3500 people answer and 350 say their engines went TU...well...I don't really care why, all 350 of 3500 couldn't have been shooting a 300 shot or something, and there is a huge issue at hand.
Old 06-27-2010, 12:00 AM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
No need to worry about the exhaust valve issue "year specific"...they're all the same valves. As you've read from a previous post, even a stainless valve can fail...
Old 06-27-2010, 12:11 AM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
I have to say that without a selection of "no problems" with my LS7 it will seem to be a LS7 bash, therefore this thread fails............
Old 06-27-2010, 12:20 AM
Jasil
Jasil's Avatar
You can't be serious maybe most novice of track rats, but with the long gears that's not even common imo........ on the street you would have to be a complete bafoon to do this.
Old 06-27-2010, 12:25 AM
Silver05GTO
Silver05GTO's Avatar
Kinda early to declare any type of results. If I started to form an opinion already as you have I'd say out of 25,000+ Z06's built only 5 of those 25k LS7's have had a dropped valve and 1 of the 5 saw the track regularly 1 was modded, only 3 failed bone stock. So 3 out of 25k vettes dropped a valve........ IMO -nothing to worry about here
ATOMIC ORANG (01-14-2017)
Old 06-27-2010, 01:59 AM
KLLRVET
KLLRVET's Avatar
Would you like to see pictures of my remaining pistons with NO eye brows from PTV contact? You are suddenly some kind of friggin expert since yours lasted 100000 miles
To Poll on LS7's with dropped valves or catastrophic engine failure
Old 06-27-2010, 03:10 AM
Dirty Howie
Dirty Howie's Avatar
Old 06-27-2010, 03:36 AM
ole
ole's Avatar
Yes I would say the same
Old 06-27-2010, 04:01 AM
foremaw
foremaw's Avatar
St. Jude Donor '08-'09-'10-'11-'12
I'm sure you will find the end result to be only a fraction of 1% of all the Z96s out there.
Quick Reply: [Z06] Poll on LS7's with dropped valves or catastrophic engine failure
