[Z06] mild to wild problem
I had my battery disconnected for a few weeks while I worked on installing my new stereo.
When I started the car the remotes wont close the exhaust nor will my homelink that I programmed before.
Any thoughts on what I could do?
So.....I suspect it's not your M2W, but rather a vacuum problem.
I had the same issue a couple years ago and thought it was my M2W and did all kinds of trouble shooting. I finally figured out that the vacuum line in the engine bay had split, so no vacuum was getting back to the solenoids to close the valves.
My vacuum leak was in the back of the engine compartment - when you open the hood, there's a line kind of right down from the driver's windshield wiper. There's a 90 degree plug that has tubing connected to it, and the tubing had split. There's a piece of corrugated plastic sheath covering the rubber tubing, so it's hard to see if it's loose or split.
I've also heard of other owners having problems with the vacuum line coming off a solenoid in the back.
I'd say check the vacuum lines to see if one has come off or is leaking.
Good luck!!
Bob
You know that thing bugged me that it would always open up every time you shut the car back off and I had to shut it every time I wanted it quiet. I ripped it back out and just wired my own tiny switch under the dash. Now, it works like normal all of the time unless I flip the switch. When I flip the switch it's open and throaty, when I don't it works just like stock......
