[Z06] Update on zr corvette creations hood.
WHATS UP GUYS ALMOST GETTING DONE INSTALLING THE ZR HOOD FROM PETE .ITS NOT A PERFECT FIT WHEN U CLOSE THE HOOD BUT IF YOU GOT A GOOD BODY SHOP WITH A LITTLE TWEAKING IT CAN BE DONE,BASICALLY THE BOTTOM OF THE HOOD IS A QUARTER OF AN INCH THICK AND IT STICKS UP A QUARTER OF AN INCH WHEN YOU CLOSE IT ,SO MY GUYS ARE GONNA DROP THE HOOD LATCH COMPARTMENTS A QUARTER OF AN INCH INSIDE THE ENGINE COMPARTMENT, AND ALSO WHERE THE STRUTS ARE IN THE FRONT OF THE HOOD YOU NEED TO SCREW A FEW BOLTS FROM THE STRUTS TO THE HOOD TO MAKE IT MORE SECURE .THE HOOD ISNT OEM SO I KNEW IT WOULD NEED TWEAKING TO MAKE IT A PERFECT FIT .BUT LET ME TELL YOU GUYS WHAT A HOOD LOOKED GORGEOUS ON THE Z ......HERES SOME PICS ......PETE IF YR READING THIS WE SHOULD BE DONE IN A COUPLE OF DAYS , I'LL BE IN TOUCH .THANKS FOR THE QUICK REPLY PETE AND THE PHONE CALL.
I WILL POST PICS WHEN IM DONE WITH THE PAINT AND INSTALLATTION
