C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 Coolant Temps with this HOT weather?
Old 08-13-2010, 12:31 PM
0Myhardtop
Former Vendor
Myhardtop's Avatar
Originally Posted by AFVETTE
We've had several days of 100+ temps with horrible humidty, my coolant temps NEVER exceeded 200 degrees even idling for extended periods. The norm has been 185 to 195.
Tom
I'm the same way. My car does not see past 185* in traffic AC on in this Texas heat and she makes over 600rwhp. On the hwy, I see 176* and I too employ a 50/50 water and anti-feeze mix with water-wetter and a 160* Stat...everything else coolant component wise is stock.
Crease-Guard above can attest to this: he rode in my car last Saturday in traffic and Hwy, our temps were in the 104 to 105* that day. We noticed my coolant, oil temps and oil psi...he noticed how much cooler and with how much higher oil psi my car runs versus his.
I see this a lot, some cars simply run cooler than others even with very similar set ups.
Thanks,
Carlos
Xxcheese (08-25-2020)
Old 08-13-2010, 12:59 PM
MallettTodd
MallettTodd's Avatar
So I think Jason along with the rest of you guys hit it on the head, the heavy modied cars are running hotter. My guess is all of us hitting in the 220-230 range have uncoated Headers and you cool running dudes have the stock setup.
My Kooks headers thru enough heat to crack my painted engine cover. Had to paint new ones and add heat tape to the underside.
So if water boils at like 242 does the coolant raise the boiling point are perhaps lower it?
Old 08-13-2010, 01:05 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Water boils at 212F at sea level. Coolant, and cooling system pressure raise the boiling point.
__________________
Contact:
(e) zach@katechengines.com
Old 08-13-2010, 02:06 PM
2k Cobra
2k Cobra's Avatar
I guess Karlifornia heat has different effects.
We have 3 stock Zs in our club and all run 220+ F in 100+ deg. stop and go traffic. All have stock coolant which I assume is 50/50. I have one bottle of Water Wetter and it helped somewhat over stock.
Old 08-13-2010, 03:29 PM
lane_change
lane_change's Avatar
Dunno...my car is not heavily modified, but I have intake, headers, etc...and my car just got back from a 40 mile drive and my temps were right around 181-186 degrees until I came to a stop light at which point I climbed up into the 190's after sitting at a red light for a while. The weather outside right now in Houston is 95' and 50% humidity (feels like 105). I am not sure what my coolant type is, never changed it since I have owned the car for the past 2 months.
Old 08-13-2010, 04:03 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,679 Likes on 1,070 Posts
Tom
What are your modifications?
Old 08-13-2010, 04:07 PM
RoHo
RoHo's Avatar
I'm with 2K Cobra, I live in San Diego and see 220 all of the time in traffic, it was the same with my C5 Z and my 07 Z until we changed the fan setting, after that I rarely saw 190.
Old 08-14-2010, 12:49 AM
outbackfarmer
outbackfarmer's Avatar
How hot is to hot? My fan locked up today, two of the bolts holding the fan motor to the shroud came out. The high temp warning came on the dic. I pulled into a parking lot and just as I opened the hood the cap started whistling and about 1/2 gallon of coolant was lost. I am running a vortech supercharger with intercooler and aftermarket radiator. I got the fan out and replaced the lost bolt. Everything seams to be working fine now. The dic showed 266 when I shut it off. I drove it about 25 miles tonight with temps around 90. It was showing 220 or less. Think I have anything to worry about?
Where can I get water wetter and how much do I need to put in?
Old 08-14-2010, 06:59 PM
K.Shupe
K.Shupe's Avatar
St. Jude Contributor
Anyone have their cooling fan continue to run after they shut the car down? I have a stock 08Z and noticed that the cooling fan kept running after I parked the car yesterday. It was a hot day, 110ish, but the car wasn't overheating when I parked it and coolant level was full. Just wondering if this is normal.
Old 08-14-2010, 07:11 PM
DaOtherOne
DaOtherOne's Avatar
When it's real hot outside my fan will run for a bit after I shut the car off.
Old 08-14-2010, 07:25 PM
2k Cobra
2k Cobra's Avatar
Hey outbackfarmer, you have a PM.
Old 08-14-2010, 08:54 PM
drabe
drabe's Avatar
I got the Vararam also, never thought about it till now blocking cool air. Makes sense tho. I see alot of u guys are upgrading the oil sump, whats that about. I have a 07.
Lingenfelter upgraded sump with Aviaid insert.
Old 08-15-2010, 09:13 AM
  #33
VetteVinnie
Originally Posted by FNQWK
i run a vararam here in vegas and in the summer time i saw a 30* increase over stock intake. it blocks the radiator and also remember our z's do not get air from underneath like the c6 only thru the grill. i do not drive the car in the summer anyway. the vararam is **** tho in the winter time sucking in chilled air i just purchased a wc hood so i will report if that disapates heat any
Well, the verdict is in. Got the Callaway installed successfully yesterday with plenty of help. On the drive over there, outside temps were in the 80s, and the car got up to about 217* on the coolant temp in stop and go. Averaged 210 on the highway. On the way home, highway cruising never got above 200. Stayed on average 194-198. Same stop and go it got up to about 205. But by the afternoon, the outside temps had climbed into the 100s. So higher ambient with cooler overall temps. Made a big difference.
And it may be my imagination, but I would swear there is improved throttle response. Maybe because the Callaway has a larger surface area on the filter and the car was running cooler overall (not as much heat soak).
Old 08-15-2010, 09:39 AM
  #34
AFVETTE
AFVETTE's Avatar
NONE 100% OEM, in fact running at Road America (4.2 mile road course with 14 turns and the two LONGEST straight aways in NA I never exceeded 235).
After over taking a GT-R on the LONG front straight - YIPEE that was fun, Interesting photo, looks like we are standing still yet we would have been pushing through 140MPH at that point. NA is the way to go.
Maybe stock has it's advantages.
Tom
Old 08-15-2010, 10:06 AM
  #35
VetteVinnie
Tom
That's what I figured. I have a host of modifications that add heat under the hood. I'll no doubt need to vent my hood before I track it.
Old 08-15-2010, 11:59 AM
  #36
tim414
tim414's Avatar
St. Jude Donor '12
I'm in North Texas where temps have been 101-104 with heat index to 110-114 everyday for past month, coupled with humidity is horrid....what little breeze there is burns your face....it's that bad....IN THE SHADE.....my '10 Z06 seems to get a lil bit warmer than my '09 Z51 Roadster did. I guess it's because of cube difference??? It got to 210 one day....so now I leave it in shop and drive my Yukon when it's so hot. I don't like my Vette baking in sun all day at work anyway....I plan to keep it a LONG time so I want to avoid the cumlative damage of this Texas HEAT/sun....VERY INTENSE and miserable....
Old 08-15-2010, 12:02 PM
  #37
tim414
tim414's Avatar
St. Jude Donor '12
Tom
Nice ride...orange my fav....
To LS7 Coolant Temps with this HOT weather?
Old 08-15-2010, 05:35 PM
  #38
texanz06
texanz06's Avatar
Default Plano
MallettTodd: "Living in the Southwest and the Temps getting to 108 here in Oklahoma, whats normal for the LS7"?
Plano, TX, about 90 minutes ago:
Outside indicated temp 101-102, but I think my car reads a little high...
206-208 Heavy stop & go traffic, mostly stopped.
203 Lighter stop & go traffic, mostly moving
201 40 MPH steady roll
196 50 MPH steady roll
Old 08-15-2010, 06:01 PM
  #39
LEAVINU
LEAVINU's Avatar
Has anyone ever considered pulling the black flexible rubber piece from underneath the front of the radiator? I installed a C6Z oil cooler in my H/C car and this piece came with the cooler. I installed it thinking there had to be a reason for it to come with it.
  • Hwy temps I saw 190-192 cruising (70-80mph)
  • Traffic in 100deg weather I saw 215-228 (a/c shut off)
I yanked the black piece out and now see
  • 174-176 cruising (70-80mph)
  • 204-212 in 100 deg traffic (takes a very long time for temps to climb now where as before it would reach 220 in less than 5mins.
I understand the Z is a front breather but why not unscrew the 6 bolts and see how it controls the temps. Doesnt cost anything and it can always be screwed back into place.
Old 08-15-2010, 07:54 PM
  #40
VetteVinnie
My understanding is that it helps prevent lift by not allowing too much air up into the nose from under the front of the car.
Quick Reply: [Z06] LS7 Coolant Temps with this HOT weather?
