[Z06] reduced power-service traction system
First post and unfortunately its with problems.
Driving on way home today and did a hard accelaration from a traffic light. Traction control was off. Did the shift from 1st to 2nd and got reduced power and service traction system alarms on DIC. I already had a check engine light that triggered earlier in the drive.
Had code p0420 which is why I didn't pay attention to the check engine light. I get that one fairly regularly even with the dealer reflash for the cats. I have a set of LG headers without cats in the garage waiting to go on, so I've been living with it.
Code that has me concerned is p0606, which has something to do with the PCM.
Car is out of warranty, so I wanted to check here before I go to the dealer and pay out of pocket.
Car is a 2008 with the only mods being Halltech CF Intake and the associated tune for it. I have 345 nitto's on the rear.
On Saturday, I got the service traction system alarm, but no check engine light. Did not show up today, so didn't think much of it. I'm on my second battery in 5 months, with the new one going in Friday. So I don't think the battery is the issue.
I did a search on this. Only thing I could find was throttle body sensors, but that did not throw the p0606 code. So that makes me think its not that.
I also saw some things on the ground to the starter to make sure the electrical system is in good shape. Where exactly is that located and can you tighten it from above the car or do you need to be under the car?
thanks
Brett
thanks
Brett
Not sure about the code but when I got my new 360 forged wheels, I got the traction control alarm under hard acceleration. It ended up being the result of my tires having too much air. Once I lowered my air pressure, the messages went away and all has been fine since.
2K,
that's my concern. Since I'm out of warranty, I want to take it to the dealer with some options instead of letting them search around.
this could get costly.
