[Z06] Weight savings mods to your C6 Z06!! Sticky??
Hello gents.... Let's have a thread going where we can all post up ideas and mods that have been either done or contemplating on doing to reduce the weight of your car!!
Now we all know that ripping the interior out will save weight but I'm looking for mods that keep all of your stock functionality and comforts and saving weight!!
For instance... Most after market two piece rotors seem to weigh less than stock and I have seen savings of upto 32lbs by doing this mod!!
Changing out the stock clutch for another lite weight unit...
Also include the pros n cons of your mod along with the weight saving #s
changing out complete exhaust with long tubes, no cats, and a light weight cat back will make tremendous gains. A lightweight battery, take the stock seats out and put in some fiberglass race type seats (huge gain there). Take off heavy clutch and replace with aluminum flywheel. Get lighter rims, tires rotors...you can easily be in the sub 2900lbs without touching the interior.
I couldn't beleive how heavy the stock exhaust was when I removed it. Saved a bunch there. Also the seats are very heavy. After than you got to spend big $$$.
Before I did some of these mods my car weight 3143 with all fluids, 1/2 tank of gas, stock exhuast and stock seat. This was with coil-overs and no leafs. I would imagine with just the seat and exhuast, I am down another 100+/- lbs.
We already have one: http://forums.corvetteforum.com/c6-z...-underway.html
What he wants to have is a post with a list of parts and how much weight each part saves over OEM.
That has been one sore spot I have had with aftermarket parts it companies like to HIDE the actually weight of their parts when weight should be JUST AS important as the gain they produce.
I like to weigh EVERY part I put on my car and replace with stock. Unfortunately I've been outta the loop due to my prison sentence in Iraq, but on my short stay at home this summer I did add my B&B Bullet exhaust addition compared to stock.
Example sticky list of weight savings:
Z06 Weight list:
EXHAUST:
OEM exhaust -----------> 52lbs (26 lbs per side minus vacuum motors)
OEM exhaust -----------> LG GT4 (-25lbs)
OEM exhaust -----------> B&B Bullets (-18 lbs)
OEM exhaust -----------> Akrapovic Stainless Steel: (-13 lbs)
OEM exhaust -----------> Corsas (-??)
OEM exhaust -----------> B&B Fusions (+/- ??)
OEM Headers/Cats------> ?? lbs
OEM Headers/Cats------> LG SuperProLongtubes 1 7/8 (-27 lbs)
OEM Headers/Cats------> Kooks 1 7/8 (-??)
OEM Headers/Cats------>American Racing 1 7/8 (-??)
Clutch/Flywheel:
OEM Clutch/Flywheel---> 56.5 lbs
OEM Clutch/Flywheel---> ZR1 Clutch/Flywheel 63.65 lbs (+7.15 lbs)
OEM Clutch/Flywheel---> Tilton Triple Carbon Clutch (-38.2 lbs)
Brakes:
OEM Front Rotor----> 26.5 lbs (53 lbs pair)
OEM Front Rotor---->Coleman 2 pc. 16.25 lbs (-10.25 lbs/-20.5lbs pair)
OEM Rear Rotor------> 26.5 lbs (53 lbs pair)
OEM Rear Rotor---->Coleman 2 pc. 16.25 lbs (-10.25 lbs/-20.5lbs pair)
Wheels/Tires:
OEM Front Wheel------>
OEM Front Wheel-------> Volk TE37 18x9.5 19lbs
OEM Front Wheel------->OZ Ultrallegerra HLT 19x10 23.4lbs
OEM Front Wheel------->OZ Alleggerita HLT 18X10 (20.4lb)
OEM Front Wheel------->Forgeline ZX3R w/Ti 18X10 (20.8lbs)
OEM Front Wheel-------->Forgeline EV1R (1 pc) 18X13 (21lbs)
OEM Front Wheel-------->Fiske Profil 5S 18X13 (20.9lbs)
OEM Rear Wheel------->
OEM Rear Wheel-------> Volk TE37 19X12 22.5lbs
OEM Rear Wheel-------->CCW Classic 18x12- 22lbs
OEM Rear Wheel-------->OZ Ultrallegerra HLT 20x12 28.2lbs
OEM Rear Wheel-------->OZ Alleggerita HLT 18x12" (23.2lb)
OEM Rear Wheel-------->Forgeline ZX3R w/Ti 18X13 (21.6lbs)
OEM Rear Wheel-------->Forgeline EV1R (1 pc) 18X10.5 (22.8lbs)
OEM Rear Wheel-------->Fiske Profil 5S 18X10.5 (22.7lbs)
Goodyear F1 Tire 325/30/19------>??
OEM Rears------------------------->Nitto Invo 345/30/19 (+/-??)
OEM Rears------------------------->Nitto NT05 335/30/19 (+/-??)
OEM Rears------------------------->Nitto INVO 345/25/20 34.5lbs (+/-?)
Goodyear F1 Tire 275/35/18------>??
OEM Front Tire--------------------->Nitto Invo 275/30/19 28lbs
Driveshafts:
OEM Driveshaft------>
OEM Driveshaft------> Carbon Fiber Driveshaft (
Seats:
OEM Driver Seat-------->
OEM Passenger Seat---->
Body Parts:
OEM Hood--------->
Superchargers:
N/A---------------> Vortech V3 w/fluids (+???)
N/A---------------> EForce Supercharger w/fluids (+???)
ALL THE FOLLOWING POSTS WOULD BE PEOPLE POSTING PARTS THEY HAVE WEIGHED..... or corrections they have found. It must be updated constantly.
.....well I got this much.. I have nothing better to do in the middle of nowhere. I'll get a comprehensive list together and post/update on a new post soon.
Well that is more a Haltech build using parts Haltech mainly sells.
Z06 Weight list:
EXHAUST:
Clutch/Flywheel:
Brakes:
Wheels/Tires:
Driveshafts:
Seats:
Body Parts:
OEM Hood--------->
Superchargers:
Z06 Weight list:
EXHAUST:
Clutch/Flywheel:
Brakes:
Wheels/Tires:
Driveshafts:
Seats:
Body Parts:
OEM Hood--------->
Superchargers:
DH
I have weighed the OEM Speedline Splitspoke Z06 wheels and below are the numbers.
~Front wheels weighed in at 22.5lbs. each with centercap (after powdercoat).
~Rear wheels weighed in at 25lbs. each with centercap (after powdercoat).
Note: I also weighed the OEM chrome wheels (made by Speedline Italy) and they were the same as above.
Made a POST on the weights I have found so far:
http://forums.corvetteforum.com/c6-z...post1575769104
Awesome feedback gents... Let's keep this going!! I'm looking to get my car in the 29XX range without giving up anything of the functionality in my car!! This can greatly help our community!!
Moderators... Can we make this a stick?? Please do.. Since this is a very active section!
Appreciate all your contributions in advance!!!
I changed the top and halo out to aftermarket carbon pieces. They were 3 lbs. lighter each, Total of 6 lbs. I did it more for the look, But it was nice to save a little weight off the top of the car.
My car's a totally stock 06' 1lz running Hoosier R6's on factory Speedline's for track day's. I'm tipping the scale's about 175 lbs myself, so thinkin' the occasional track day set up is pretty good.
Supporting Vendor
St. Jude Donor '09
