[Z06] Z06 OEM and Aftermarket Parts Weight List
Sorry Blaine the wheight of the OEM manifold 25.8 for both , so the total wheight for the factory exhaust system is 115.80 , seat wheight Sparco EVO 19 LBS , O M B hte 20.6 lbs
Cobra 20.4 , i have Carravagio seat in my car forgot to put them on the scale before install ....opp . for the tire they are 325 (came with the car ).
Which type of Cobra Seats?
O M B hte 20.6 (Not sure what u mean)
More wheight . OEM engine mount 8 lbs / OEM transmission 4 lbs / OEM front sway bar 8.2 , back 11.8 / seat mount PFADT 5.4 LBS .
Great thread!
Also good to remember that wheel/tire weight is very important; every 1lb taken off of a wheel (rotational mass) is like losing 6lbs off the car itself.
Added more weights.
Wheels/seats/tires/batteries/total car weight of Carbon
Still could use more weights.
I would like to know the weight of the stock lug nuts compared to the titanium lug nuts. I'm going to need lug nuts when I get home. My car still has a couple locking lug nuts.... and I wasn't given the lug nut key when I bought the car.
Aftermarket seat weight list update with most common aftermarket seat upgrades.
Surprised at some of the results.
Caravaggio Leather Race Seats are my big surprise....looking like an even better upgrade. And the heavier Caravaggio Daytona seats are very light compared to the other alternatives which have 1/2 the comfort options as the Daytonas.
#35
Updated List.
List comes in handy already. Just by paying attention to what you buy in parts you can save a TON in rotating mass just in wear items alone!! For example:
Time to replace rotors: Colemans or ATX 2 piece rotors front and rear -24lbs
Time for Tires: Michelin Pilot Sport R's or Conti Sports -32lbs.
Time for a new clutch: RPS Street Twin Lite w/alum fly or LG Triple Carbon -38lbs
Just by paying attention to weights: You just lost 94 LBS of Rotating mass!! Getting a 06 Z06 below 3000lbs isn't rocket science. 3130-94= 3036lbs Add racing seats... DONE.
#37
Z06 hood 23.1 lbs.
ZR1 hood=12 lbs
Z06 front fascia= 14.3 lbs.
Z06 rear glass=23 lbs.
fuel tanks(2)=24.71 lbs.
windshield=31.94 lbs.
door glass(2)=15.52 lbs.
door(SMC)(2)=28.35 lbs.
door weatherstrip(2)=1.59 lbs
windshirld weatherstip=2.47 lbs.
rear hatch weatherstrip=1.87 lbs
Front bumper energy absorber=3.66 lbs.
front fender brake cooler duct(2)=.73 lbs.
Z06 rear qtr panels(2)=15.21 lbs.
rear bumper fascia=14.4 lbs.
rear bumper energy absorber=3.31 lbs.
rear brake cooling duct(2)=2.43 lbs.
rear wheel opening molding (splash guards)(2)=.82 lbs.
seat lower foam(2)=2.95 lbs.
seat center foam(2)=4.17 lbs.
seat upper foam(2)=3.26 lbs.
seat belt webbing(2)=.66 lbs.
seat frame back(SMC)(2)=13.16 lbs.
hood weatherstrip=.74 lbs.
master cylinder reservoir=.33 lbs
valve cover shield(2)=2.54 lbs
power steering pump reservoir=.53 lbs.
plastic side radator tanks(2)=1.72 lbs.
plastic radiator bracket=1.5 lbs.
radiator cooling fan frame=3.31 lbs.
ZR1 hood=12 lbs
#38
Z06 hood 23.1 lbs.
ZR1 hood=12 lbs
ZR1 hood=12 lbs
WoW....u didn't just take apart your car?
Going to need another person to verify if the weight for the OEM hood as 27 lbs or 23.1 lbs.
#39
Updated List.
my old head has a hard time with that........
