[Z06] Z06 OEM and Aftermarket Parts Weight List
#41
Stock hood weight...depends on how you weigh it, as in, does it include the hood liner and (in the case of the '06) the under hood light.
The weight I got for my stock '06 hood (stripped of liner and light) was a little more than 23.1 but still under 24 lbs.
Cheers, Paul.
Cheers, Paul.
#42
Cheers, Paul.
Cheers, Paul.
#46
Hi Blaine,
Where did you get the wheel weights for the HRE R40's?
Just wondering why the weight difference you have listed for the front and rear even though the diameter and widths listed are the same? Different offsets maybe? I'm very interested in possibly purchasing these wheels, and just wanted to confirm your source and accuracy?
#47
Hi Blaine,
#48
Added more wheel weights.
No one has anymore weights? No ones bought a hood? Rotors? Brake kit? Tires? a supercharger? Turbos?
Still need rear ZR1 spoiler weight/rear exhaust panel/OEM Halo/roof/about all supercharger/turbo kits/
Funny how the Corvette became a Z06 because of the 50+ lighter weight than a base Corvette, but so few cares about the weight.
Almost 90% of every forum post on this site has at least one question regarding weight...
"How much does that seat/tire/wheel/exhaust/brake rotor/hood weigh compared to X?"
#49
Having weighed several original ('06 and '07 MY take-offs) Z06 rims, weight does fluctuate quite a bit.
#50
#58
2010 Grand Sport style chrome
Wheel Weights
Front 18x9.5 = 26.5lbs (+5lbs each)
Rear 19x12 = 29.5lb (+3.5lbs each)
+17lbs over OEM for a set
*reproduction GM spec may be different +/- lb
Hard to beat the weight of the OEM wheel and tire combination. The OEM wheels and tires are VERY light and there are only a few aftermarket options that save weight compared to them.
LIST UPDATED
Wheel Weights
LIST UPDATED
#59
I installed the ATI 10% underdrive pulley today. I had a chance to weigh them both on a very accurate shipping scale back to back. The weight you list for the stock pulley is 10lbs. My scale read 9lbs 12.6oz. The ATI pulley including the hardware(2pc pulley) weighed 8lbs 6.4oz. So a net savings of 1lb 6.2 oz in rotaing weight in addition to being 10% underdriven.
