C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 06 2LZ weight full tank
Old 11-14-2010, 02:17 PM
HoustonSVT
HoustonSVT's Avatar
Default 06 2LZ weight full tank
Had my 06 2LZ weighed just now and wasn't real happen when I got the ticket.
This was on a CAT scale.
Just filled up the gas tank to as much as it would hold.
I also had a few items that would increase the weight a little.
Jake floor mats (4-5lbs?), trunk partitioner (1-3lbs?), corvette racing cargo mat (3-6lbs?) Apsis splash guards (1lbs?).
With all this came out to exactly 3180lbs.
I thought the 06 1LZ was 3132? And the 2LZ package is about 12-14lbs?
Does GM really weigh with a full tank of gas?
Are these truck stop CAT scales pretty accurate?
Old 11-14-2010, 02:21 PM
HoustonSVT
HoustonSVT's Avatar
Everything else is stock, down to the runflats.
Old 11-14-2010, 04:38 PM
JohnTheStigGalt
Support Corvetteforum!
JohnTheStigGalt's Avatar
I thought I read somewhere that GM weighs with 1/4 tank of gas...
A gallon of gas weighs about 7 lbs.
Old 11-14-2010, 07:29 PM
2k Cobra
2k Cobra's Avatar
If I remember correctly, the 2LZ weighs 3160 with a 1/4 tank of gas, as mentioned above.
Sooo, you should be about right with the mods..
Old 11-14-2010, 08:04 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
gas weighes ~6.25 lbs/ gallon.
Curb Weight
= Vehicle built with standard equipment + all fluids (fuel, oil, coolant)
This is the weight of an empty vehicle built without options (except if equipped with optional engine and air conditioning), without cargo, without driver and passengers, but it does include the maximum capacity of fluids such as a full fuel tank, oils, coolant, etc.
Spare tire and changing tools are standard equipment and included in the curb weight.
Old 11-14-2010, 08:51 PM
HoustonSVT
HoustonSVT's Avatar
Curb Weight
Thanks, did that source give an idea of what the 2lz should weigh?
Old 11-14-2010, 09:25 PM
HoustonSVT
HoustonSVT's Avatar
Just looked up the 11 Z06 and the curb weight is listed at 3175 for 1,2, and 3LZ. Surely my 06 weighs less than the new 11?
Old 11-14-2010, 10:38 PM
JDMUSCLE
JDMUSCLE's Avatar
Most truck scales are rounded to the nearest twenty pound number!! My 2LZ with a quarter tank of gas, helmet, and a bunch of crap in my glove n center compartment weighed 3108 at the track!!
Old 11-14-2010, 11:00 PM
HoustonSVT
HoustonSVT's Avatar
Whoa, that could make for a huge difference. Thanks for the info.
Old 11-14-2010, 11:01 PM
C6___Z06 LW,FL
C6___Z06 LW,FL's Avatar
My 06 2LZ is 3076 from the factory
Old 11-15-2010, 12:42 PM
HoustonSVT
HoustonSVT's Avatar
Just confirmed with the cat scale folks, they go towards the nearest closest 20 pounds. So by my bad math I guess there could be upto an 18 pound difference, I will try to find a more accurate scale.
Old 11-15-2010, 12:43 PM
HoustonSVT
HoustonSVT's Avatar
Is that with a full tank?
How could there be a 100 pound difference in the same car, year, and package level?
Thanks for the input....
To 06 2LZ weight full tank
Quick Reply: [Z06] 06 2LZ weight full tank
