C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] will any cam pass smog test?
Old 11-19-2010, 04:59 PM
flatout vette
flatout vette's Avatar
Default will any cam pass smog test?
Want to install aftermarket cam but my state has smog inspection. Will anything work for me. Thanks
Old 11-20-2010, 12:42 AM
JMB
JMB's Avatar
You just have to get a bit creative. I used cats on an LS1 set-up before with a 236/236 cam and ran about a 50% mix of alcohol and leaned the idle out/raised the idle speed and was able to sneak it through the sniffer! Should be able to run a bigger cam than this with an LS7.
Old 11-20-2010, 02:29 AM
The running man
The running man's Avatar
The biggest cam that I've heard of passing Ca smog was in a 442 LS7 stroker. The specs were 230/239 on a 112 LSA. With that said their should be quite few options for you when it comes to picking a cam that will smog.
Old 11-20-2010, 03:12 AM
filmjay
filmjay's Avatar
St. Jude Donor '10
Will be finding out if mine does next week......
Old 11-22-2010, 01:05 PM
r6elmo
r6elmo's Avatar
i would be interested in this as well. It's really the overlap more so than lift/duration. It sounds like anything 5 or under should work.
To will any cam pass smog test?
Quick Reply: [Z06] will any cam pass smog test?
