[Z06] Handheld Tuners = Junk?
Has anyone tried using handheld tuners such as "Diablo Predator" or "SCT Power Flash"??
They seem to be aimed more toward f body/ 2000s mustangs and stuff like that instead of LS7 crowd..
Would you say its just better to outright get a real tune instead of cheaping out on a "toy" like this or does it actually work well?
It works in the sense that you will see gains, but every motor is different. So you will not see the gains or the reliability possible with a (properly done) custom tune.
They're marketed much more to the f-body/mustang crowd because they're a cheaper solution to the real deal.
I wouldn't use the pre-installed "Factory" or "Defualt" tunes in these handhelds that come from the manufacturer. They are a little too generic IMHO. However these handhelds do work well as a acceptable transport/upload vehicle for taking a custom tune that's emailed to you and getting it moved from your PC and uploaded to the ECM in your car. Just be sure you know what type of software your "Tuner" uses so you know which handheld unit is supported.
U.M.
U.M.
I would never use the generic tunes either. I had one on my cts-v....and intermittently and randomly it would drive like complete **** sometimes. I.e. Monday - thursday she was a champ, turn her on friday....limp mode, horrible sounding....
took the tune off, never had another issue.
However, most tuners use one of these handhelds to load, store and unload custom tunes.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
Handhelds leave identifiable files behind in the PCM even if you reload the factory program. They WILL permanently change the CAN codes that GM so passionately checks if there's major warranty claims for drivetrain damage. HP Tuners, for one, leaves no trace once the factory program is re-loaded. It was my dealer that let me know this and advised accordingly...
Aside from that, I'd never run an "engine destroying" canned hand-held program in my Z06.
I have a preditor for my Cherokee. The loaded tunes were junk and made my truck lose power. it wasn't till i got a custom CMR tune that made it worth it.
I would never use a pre loaded or "Canned" tune in a corvette.
just my .02
just my .02
http://forums.corvetteforum.com/c6-c...-sale-now.html
U.M.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
It's a very slick transport device....
I was told this is not true for the EFI Live Autocal unit that Chuck CoW sells... or is this Autocal not really a handheld tuner and more of just a transport device?
U.M.
U.M.
Hand-helds have a bad rap and this is no ordinary hand-held.
After it's loaded into your car, I can datalog the car with AutoCal and
adjust the tune to make it perfect.
Call me any time if you're interested.
Chuck CoW
i have the diablosport trinity. I've just started to use it so I can't comment just yet. I like how it has the ability to hook up a wideband o2 sensor etc. The tunes that come in the handheld tuners are probably not worth it, but it's worth it to have a CMR tuner do it for you. They can take your logs, and from that adjust accordingly.
Cruising
he means your handheld can carry more that one tune at a time. for example, say you are planning on spraying at the track you can just upload that tune when you get there, then before you leave you can put the other tune back in.
Hand held tuners are very helpful, not only for transporting tunes but also as a dataloger so you can make sure your car is running perfect and check all the parameters, otherwise without a true dyno tune, you dont know for sure the engine is running perfect
I don't know anything about the others, but Hypertech has worked great in my '02 for over 6 years now. And if I would have tried one on my Z06, which I would never do, it would have worked well also. Propably not the totally perfect tune, but a noticable difference in the right direction, for a reasonable price. Just my $.02.
The SCT X3 device flashes and returns to stock in the same format as HPtuners or EFI Live, once returned to stock the calibration section of the pcm is a 100% byte for byte binary match to the file that was read out and stored as stock.
If the OS section is flashed with the handheld that too is a 100% binary match to the data that is stored as stock file.
For those who are not familiar with the SCT X3, it will hold up to 3 custom tunes from your custom tuning dealer. You can receive tunes both in person or e-mail from ANY SCT custom tuning dealer unlike the EFI Live Auto Cal device that must come from the tuner who bought the unit. All X3 devices come with analog inputs for 2 0-5 volt devices such as widebands.
Ryan
Cruising
1998ws6370 is right, the tuner doesnt change the stock tune at all, stores it in the system and when returned to stock it puts back in the same exact tune. but it is traceable. the dealership can get a printout from your pcm and see how many time it has bee reset and connect the dots if youve put a tune on or not
Former Vendor
The AutoCal is a fantastic tool....
It's internally, virtually identical to my personal EFI LIVE V2 tuning cable
with a smaller screen and fewer buttons....
The best part about AutoCal is that it can deliver EXACTLY the same tune I can create in person.
Other hand-helds are somewhat limited in that they can only load tunes created by their parent software....
It is recognized that the EFI LIVE is a leader in the LSx field and ANY tune created with it can by loaded by the AutoCal.
Anything custom I can do here in my shop can be done remotely with AutoCal.
Chuck CoW
Chuck CoW
So I can send your customer a tune to load on your autocal device built from my efive software? Or do you mean any tune you have in efi format you can send to your customer?
Ryan
Ryan
Former Vendor
Any tune I choose....
I have to save the file in the new .ctd format and it will work in the autocal that is linked to my V2 cable.
Chuck CoW
What if?
What if you are no where near a tuner?
Remember Canada and Mexico ?
I just got the cmr kit and tunercats.I had Hpt pro and had a tuned with efilive.they are all tools to the same end.the predator multi tune thing is cool if you are custom tuned to the edge for when traveling.good gas is not always available.this Talk on finger printing the ecu is real. But not at the dealership .if the engineers look they will find.at this point you probable have a lawyer anyway so prove I did it.
I have some experience with a few tuners.to much
They all have a following ,it 's like when you get the first good bj , only good till the next best
I am am planing my next interstate tune trip.floria,ga ,la.?
Or maybe Birmingham .nothing here for turbo car
Mike
Sorry iPhone
Mike
Sorry iPhone
