C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 shifter noise
Old 12-20-2010, 06:10 PM
Rudydog
Cruising
Rudydog's Avatar
Default Z06 shifter noise
I have a 2007 Z06 and the shifter rattles in 2nd gear but only at 4000 rpm and up. Any thoughts would be appreciated.
Old 12-20-2010, 06:19 PM
dmuellenberg
dmuellenberg's Avatar
http://forums.corvetteforum.com/c6-z...er-rattle.html
Old 12-20-2010, 06:22 PM
speedy77
speedy77's Avatar
Do a search...there's tons of posts about this issue. It's a common problem.
Old 12-20-2010, 06:50 PM
Rudydog
Cruising
Rudydog's Avatar
Im new, how do I do a search? thank you
Old 12-20-2010, 06:56 PM
skudlw
skudlw's Avatar
You need to replace the shifter with the updated GM model. Mine did the same the first year I owned the car and GM replaced it under warranty.
Old 12-20-2010, 08:07 PM
ClarksZ06
ClarksZ06's Avatar
skudlw- I have an early 08 Z, and I get some whining noise when i'm in the shift, is this what your talking about?
Old 12-20-2010, 08:17 PM
JRB
JRB's Avatar
is c6shifter and z06shifter the same
Old 12-20-2010, 10:24 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Whining and rattling are probably different.
Old 12-20-2010, 10:31 PM
Marc Lefebvre
Marc Lefebvre's Avatar
Marbles in a can syndrome. Pretty commom from what I have read. Mine does it also.SKUDLW said GM replaced his under warranty, think i'll check into that this spring. Good luck. Marc L.
Old 12-20-2010, 11:10 PM
vetteship
vetteship's Avatar
Here you go, I did the write up a whileback:
Old 12-20-2010, 11:13 PM
vetteship
vetteship's Avatar
Marc,
The marble in a can is not what he's describing. The marble in a can sound is when driving slow at low RPM, parking lot in 2nd gear, etc.., and that's due to the torque tube converter design. His issue is what I posted above.
Old 12-21-2010, 10:09 AM
skudlw
skudlw's Avatar
Talking about a rattle noise, not whine. Mine started rattling at about 2000 miles and was replaced by the dealer with the newer model shifter.
To Z06 shifter noise
Quick Reply: [Z06] Z06 shifter noise
