C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wheel spacers??
Old 01-26-2011, 04:59 PM
  #41
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Originally Posted by h2oskiman
Go to home depot or lowes and buy some 7/16 zinc washers they fit right over the studs without any movement you can add or subtract as many as you need to do the job but i wouldn't go to far.I have done this and it worked well just my 2 cents I had bought some wheel spacer's but they didn't fit as well as I liked went this route and it worked well You may need three or four per stud depending
your kidding right? That is out right dangerous. I would NOT want anyone here to try the same thing unless it was on a wheelbarrow pushed under 5 mph.
First unless you have bought graded washers they are different thicknesses because regular washers are made from scrap. Look at a stack and you will see they are all different. Secondly your im is just touching the washers not the entire hub flange to take the load. Thirdly if you put to many like over 1/4" you hub flange is not engaged and all the load of wheel impacts will be on the studs and not the hub flange.
AND you rotors and rim will not be getting the same load on each torqued lug nut!
where did you buy the wheel spacers?
Old 01-26-2011, 09:13 PM
  #42
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 09:14 PM
  #43
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 09:15 PM
  #44
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 09:20 PM
  #45
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 09:21 PM
  #46
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 09:22 PM
  #47
JsnMR2
JsnMR2's Avatar
  #48
JsnMR2
JsnMR2's Avatar
Old 01-26-2011, 10:15 PM
  #49
HoustonSVT
HoustonSVT's Avatar
Thanks for posting the pics, it does look so much better like that. However I still think more in needed for my taste. Maybe 1/2 front and 3/4 back.
Old 01-26-2011, 10:20 PM
  #50
JsnMR2
JsnMR2's Avatar
3/4" back would stick out past the fender by far. With my DR's the tire is going to be 100% flush with the fender in the rear.
For the front.. Front could use another 1/8"-1/4" more. I didn't want to risk fender rubbing.
Old 01-26-2011, 10:28 PM
  #51
HoustonSVT
HoustonSVT's Avatar
What did you do on the studs? Replace them yourself or have a shop do it? If a shop did it what did they charge?
How many hours?
Old 01-26-2011, 10:33 PM
  #52
JsnMR2
JsnMR2's Avatar
A shop did it. To do studs + lowering bolts it was $300.00
Old 01-26-2011, 10:37 PM
  #53
HoustonSVT
HoustonSVT's Avatar
Cool, You did 3/8 front and 1/4 in rear right? For some reason I'm thinking the larger spacer should be in the rear?
Old 01-27-2011, 01:38 AM
  #54
JsnMR2
JsnMR2's Avatar
Yup 3/8" front and 1/4" rear. I was going to do 3/8" all around but wanted to make sure my DR's clear. I'm glad I did it this way.
For someone staying with stock tires.. I'd probably for 1/2" front and 3/8" rear..
Old 01-27-2011, 08:56 AM
  #55
ajbarbato15
ajbarbato15's Avatar
Jsn, thank you so much for all of your helpful information and pictures throughout this thread. I have been waiting for someone to post pics with spacers for months now. I placed my order with DRM last night! Ill add some pics to this thread when mine is done as well!
Thanks again!
Anthony
Old 01-27-2011, 11:00 AM
  #56
John Shiels
How many hours?
You can tap out the studs but you really don't want to do it while the hub is on the car and hammer the bearings. Then you can tighten them up with and air gun and some spacers like a socket to pull the splines into the hub.
Old 01-27-2011, 11:15 AM
  #57
MTIRC6Z
MTIRC6Z's Avatar
You can tap the stud out of the hub, but you'll never get it out from behind the hub much less get the new much longer stud back in. On my C6Z I tried every which way and ended up having to remove the hubs to get the job done. Can't imagine there something particularly different about my specific car.
Can I assume you haven't actually changed studs on a C6Z?
Cheers, Paul.
To Wheel spacers??
Old 01-27-2011, 12:12 PM
  #58
JsnMR2
JsnMR2's Avatar
Yes hubs had to be removed
Old 01-27-2011, 12:13 PM
  #59
JsnMR2
JsnMR2's Avatar
Thanks again!
Anthony
Awesome, what size did you go with?
Old 01-27-2011, 12:30 PM
  #60
ajbarbato15
I went with the same sizes that you used, as I am running the same rear tire (345 NT05R) and a 285 front.
Anthony
Quick Reply: [Z06] Wheel spacers??
