[Z06] skip shift
skip shift
Do many people drive their cars without disabling it? Since I live in California with the super strict smog laws, will disabling it cause trouble with the OBDII codes?
If you use the CAGS eliminator that connects to the transmission wiring, you won't get any codes. $20 well spent. Install it and forget it. You can then shift when, and to what gear, you want to, not when the computer thinks you should. Take control of your life.
Received 8,928 Likes
It isn't that hard to drive around. Skip shift only activates between 14 and 20 mph if you are driving behind a slowly accelerating car. If you shift to second before 14 mph or after 20 mph you will never know skip shift existed. If you are aggressive on the throttle and accelerate at a normal rate skip shift will not activate even between the two magic numbers. I only have it activate on me if I am driving behind a slow driver in a low performance car and I forget and shift at the wrong time. Since I am not often in that position I have never spent the money to do anything about defeating it even though I have had cars with CAGS since 97. Even if I drove in heavier traffic where I would be in that position more often I think I would quickly get used to shifting sooner in that situation. Any Corvette can easily run in second gear at 13 mph. The minimum cost to defeat this feature on a C6 is a few minutes of time and a couple of dollars for the fuse mod and it just isn't worth the time or the money to do it. I would spend the time washing my shoe laces before I would do this mod.
Bill
Bill
I had mine eliminated in a tune. I would rather not have to work around it.
Larry
Larry
The skip shift eliminator was waiting in my toolbox before my ZO6 was delivered. I installed it the same day I took delivery of my car.
After about 6 months the "check engine light" came on. I went to the local dealer to have it checked out. The skip shift eliminator resistor had failed and the check engine light came on.
Since the skip shift eliminator was an aftermarket component that caused the problem the dealership took it out, reset the code and charged me an hour labor for the diagnosis and the fix.
I've never replaced the skip shift eliminator. I, like several other posters, have just learned to drive around it. It is very rare that skip shift kicks in. It still pisses me off when it does, though.
I rarely hit the 1-4 problem but when I did, it really got on my nerves. I used the "blown fuse" method and am pleased with the results. Not bad for $2 and a few minutes.
Here's a link to everything you ever wanted to know about disabling CAGS. Your choice, $20 or $2. http://xse.com/leres/z06/cags.html
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Bill
Bill
go through the gears.
Shifting becomes second nature and you become used to shifting without thinking about speed, RPM, etc. With the CAGS, you have to input some thought into the shifting to either shift earlier, or to shift later, then what feels natural, because of the Nanny called a computer. When an outside force starts to influence your actions, it's not second nature.
I could also drive around town in 1st gear 100% of the time and never worry about shifting at all, until I got on the Interstate highway driving above 60 MPH. But I prefer to drive the car the way I've been driving standard shift transmissions since I learned to drive my Mom's 1952 Chevy back in 1955 when I was 13 years old. I've had my drivers license since I was 14 years old, and never had to worry about driving "around" the shift points that a computer says I should shift into 4th. $20 spent for a CAGs eliminator and I get to drive the way I've been driving for the past 55 years.
Bill
Bill
Please resume your normal activities!
Unless they can't figure out the exact problem and end up replacing the entire fuse box.
