[Z06] Halltech Killer Bee II w/Bee-Hive.....
If I install ARH (1-7/8"), X-pipe and cats (rear O2 sensors disconnected) -AND- a Halltech Killer Bee II w/Bee-Hive CAI ....(without a chassis dyno tune).....
...... then drive my '07 Z06.... 250 miles to the shop to get a tune ....will my car be alright? Will I be able to make the 250 mile journey to the Shop for a tune without any driveability issues?
yes. I did this on an ls6.
Drive slow and passively. You may have a few minor driveability issues (idle, surging, etc)
You will throw a code along the way. But so long as you do not drive hard/high rpms....you should be ok.
So, if I drive it like I am driving the family in a 4 door sedan (Honda) through traffic and excellerate slowly to hiway speed (70mph) and be easy and mellow the entire trip ....I should be able to make the journey without much, if any mechanical drama? Good deal!
Supporting Vendor
St. Jude Donor '09
You will get a check engine light from the disconnected rear O2 sensors, which will not hurt the car. Your tuner can deal with that.
The front O2 Lambda sensors are the closed loop sensors that tell the ECM how much O2 or fuel is left over after combustion. It adjusts the injector pulse width to keep the motor running stoichiometric when you are under 48% throttle position. When you go past 1/2 throttle you trip into open loop fuel enrichment where the MAF sensor alone adjusts pulse width and the Long Term Fuel trims have zero affect on the burn.
Why are you disconnecting the rear O2 sensors? You should have had extensions in the kit.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Absolutely no issues with the Killer Bee II/Beehive. We designed the Killer Bee II as a no tune, no surging, no warranty issue intake. Period.
Thank you for the feedback!
After I install the headers, cats & X-Pipe ....my tuner told me to leave the REAR O2 sensors disconnected, drive to his shop for tuning, and he will deal with the rear O2s during the tune.
