[Z06] F-2 ProCharger Bracket and 50mm COG Drive System by Dallas Performance
Former Vendor
Well after hundreds of hours of design and development we are ready to release some teaser pics of the Dallas Performance F2 Bracket and Dedicated Cog Drive System.
Some important details about our F2 bracket and drive system:
* Blower maintains DP Big Mouth Air Filter and 4.5" inlet ducting
* Works with modified factory water pump or Meziere electric WP
* Full 50mm wide COG Drive System
* Allows for mounting of F2 ProCharger with STOCK C6 hood
(Stock C5 should clear as well but is untested)
* Brute overkill in bracket rigidity to minimize harmonics
* Easy access to tensioner for adjustments
This system will work with D1/F1A/F1C/F1R/F2 ProCharger Headunits on your LS1/LS2/LS3/LS7 based engine.
Currently taking pre-orders with intro pricing set at $3999 for first 10 systems.
DP/F2 System includes:
* 50mm Cog Blower Belt
* 50mm Cog Billet SFI Balancer
* 50mm Cog Blower Pulley (sprag option +$400)
* 50mm Hard Anodized Idler Pulley
* Billet Supercharger Main and Sub Brackets, Anti Flex Beams
* Billet Bracket Spacers, Tensioner Assembly, All Hardware
* DP Direct Drive System
* Stainless Steel Power Steering Hose
* 4 and 6 rib Belts
* Black or Clear Annodized Finish
http://www.youtube.com/watch?v=DnTBehMM_-Q
* 4 and 6 rib Belts
