[Z06] Installed Coleman Slotted Brake Rotors
#41
yeah I went through the same thing buying my Z06. Local dealer wanted an extra $10,000 OVER MSRP for " regional demand" here in Colorado.
So I bought my car from Kerbek at $8,500 UNDER MSRP and had it delivered for $1,100. I figured if he knew the market better than me....good luck getting an extra $17,XXX for the same car same warranty.
That thing was sitting there forever....at least he tried
I'm still amazed that many of these characters don't see the double dip that's coming.
#42
#43
I've been using colemans rings and performance AFX hats on the track since fall 2008 after talking with Bob Finlayson. I would run nothing else on the track. These rotors ( combined with Cobalt pads and proper cooling and SRF fluid) are Incredible! they last and last..
Here are pics with both front CCW wheels and stock C6Z wheels. I'm on my second set of rings in the front. The hats have discolored a bit over time with LOTS of heat. But then again thats what I bought them for.
As others have stated, I have to admit that the car does feel better when these are installed. I just added take-off ZR1 wheel/tires and can notice that additional weigth too.
NOTE: rotors were installed incorrectly with the stock caliper pics....but you get the idea.
#44
Beautiful brakes! Thanks for the post
I'm in the market for a set of rotors...I think these baby's get the
Out of curiosity, what's the difference between the Coleman and the AFX or LG rotors?
#45
There are plenty of people who refuse to see the Double Dip (or a decade or two of lost growth, IMHO) - there is no specific professional requirement to have that viewpoint.
But, to play Devil's Advocate: I've been waiting for that Double Dip for three years now. I have to tip my hat to the Powers That Be - they've done a great job at delaying the inevitable for their own uses (abeit at tremendous cost).
#46
I got my reply:
"Byron,
We have floating and solid mount rotors, and rears with the e-brake provision. Solid mount rotors sell for $385 and floating rotors are $450.
Let me know if you have any other questions.
Regards,
Daniel Finke
Finspeed, LLC
715 Sturgeon Street
Moberly, MO 65270
Phone: 573-446-1444
Fax: 573-514-4047
Email: daniel@finspeed.com
Web: www.finspeed.com"
"Byron,
Regards,
Daniel Finke
Finspeed, LLC
715 Sturgeon Street
Moberly, MO 65270
Phone: 573-446-1444
Fax: 573-514-4047
#47
Love those rotors. If I stick with the stock system, those are the ones to get a long with a set of one piece single pads.
I understand this is an old thread, but in case you happen to stumble upon it... Any feedback on the compatibility with the OEM Hand/E-Brake? I assume each rotor was quoted at $450, not the whole set?
#48
I don't think there is much if any weight difference in weight.
#49
Both types are 2 piece with the following differences: Floating rotor have different mounting hardware and allow for minor side to side movement and expansion and contraction of the ring. Solid rotor don't really allow for any side to side movement or expansion/contraction of the ring. It is said that floating rotors can make more noise because of this movement.
#50
This increase in gap - or "slack" in the caliper pistons - relative to the surface of the rotor can result in a loose-feeling pedal. How loose depends on the braking system, the amount of deflection, wheel movement, etc etc.
So "floating" is ideal from a braking performance perspective - but as with all things there is a trade-off: the mechanisms used to float the rotor relative to the hub (allowing the rotor to move and stay centered in the caliper) often creates a decent amount of noise. For reference, most OEM systems are non-floating, and very few people notice any soft-pedal effects because they just don't push the braking system that hard. For *most* people, the floating system is not necessary, and probably would be frustrating from a noise perspective.
But that's just what I picked up from the internet.
#51
Anybody else having issues with extreme rusting on these rotors? Any part that isn't touched by the pad is rusty, including inside the slots. I guess it's my fault that I should've asked if these are zinc coated before buying, but I assumed that they were for the money. Is there a performance reason for this? The huge weight savings is awesome and they work flawless on the street and track, so overall I'm happy. When people comment I tell them it's because they are a 'race' part, so it's not a big deal. I just expected them to look a little nicer for my $1500.
#52
That should buy you a few years... but I agree - I noticed these aren't zinc coated and I find that odd, considering that aesthetic is important to a LOT of Corvette owners.
#53
Mark off the rusted areas with tape (the pad path), bead-blast the rust off and then coat with hi-temp black paint.
#54
Received 8,928 Likes
Bill
#55
I just checked it out online and it's not too bad: $20 for a 1/2 pint can of it.
http://www.advanced-rust-protection....ry_Code=HiTemp
#56
#57
