C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] obdII code is p0449
Old 03-29-2011, 05:58 PM
msnbound
msnbound's Avatar
Default obdII code is p0449
apparently, it's an evap problem?? any relationship between getting my exhaust installed and this code?? TIA
Old 03-29-2011, 05:59 PM
spoon man
spoon man's Avatar
yes it is most likely unplugged. it won't scan out so you need to fix
Old 03-29-2011, 06:44 PM
msnbound
msnbound's Avatar
where is it located??
Old 03-29-2011, 07:45 PM
spoon man
spoon man's Avatar
It is a little black box about the size of a pack of smokes. it is next to the trans on the passenger side. I am almost sure it is unplugged if it just happened after an exhaust install.
Old 03-29-2011, 07:50 PM
msnbound
msnbound's Avatar
thanks man....after doing some research, it could also be a relay fuse (#13).....going into reverse is also more difficult and the same fuse also powers the reverse disengagement on MN6 cars........
Old 03-29-2011, 08:12 PM
Z06ReCruiT
Z06ReCruiT's Avatar
I installed Akrapovic exhaust and also got a cel. I fixed mine today. It was just unplugged.
Old 03-29-2011, 09:31 PM
spoon man
spoon man's Avatar
that could a mental thing about the reverse. Let us know what happened so people can learn from our mistakes Good luck.
I am betting it is just unplugged
Old 04-05-2011, 08:44 AM
Z06ReCruiT
Z06ReCruiT's Avatar
Hey the reverse is defiantly not a mental thing I has the same issue.
Old 04-05-2011, 07:28 PM
msnbound
msnbound's Avatar
but i didn't get the evo system so the installer didn't have to touch anywhere near the sensor.......weird.......replaced the fuse.....reverse works smoother now, cleared the code.......but it cel keeps coming back on......
Old 04-05-2011, 07:34 PM
Z06ReCruiT
Z06ReCruiT's Avatar
Mid pipe would not hit the sensor or unplug. The mufflers pipe would so when removing.
Old 04-05-2011, 08:14 PM
cyi1
cyi1's Avatar
2018 C7 of Year Finalist
my 06 did the same exact thing a few months ago out of nowhere. Luckily I have GMPP coverage. The receipt from the dealership says, "Open Circuit in vent solinoid, check and replace solenoid." Had to overnight it so they could get the part but it was fixed the next day.
It was right after I switched from corsas to borlas...not sure if that had anything to do with it
Old 04-28-2011, 11:58 AM
msnbound
msnbound's Avatar
that was exactly what happened to me....they had to overnight it also....warranty only covered part of it, saying neglect with the fried connections.....bastards
To obdII code is p0449
Quick Reply: [Z06] obdII code is p0449
