C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Michelin Pilot Super Sport 345/30ZR19
Old 11-30-2011, 08:43 PM
  #61
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
Other than DOT rated race rubber, I think the Super Sports will be the tire that all the other MFRs set there cross-hairs on. They could be the 1st true 40,000 mile performance tire. I will own a set as soon as they debut.
I'm on my second set of PS2s now, with 59K total miles. I run the 275/345 combination. When I put my 1st set on I got the warning light once, on a high speed braking maneuver. I never got it again. I honestly think the BCM has an adaptive learning function and after a while the slight mis-match in tire height is allowed for. A wider front tire is not necessarily a good thing. A bulging sidewall will compromise cornering capabilities negating any benefits realized from an increased contact patch.
Old 12-01-2011, 12:01 AM
  #62
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
The M PSS 285/35-18 is sized for a 9 1/2 to 11" rim, so M is happy with it performing on a stock Z06 front rim and it has about a 1/2" more tread than the 275, thus should have more grip and come close to maintaining the stock front/rear balance if a 345 rear is used. I'll still probably go with the 275/325 combo as my 335 NT-05's rub on the inner fender liner due to their higher overall diameter and the PSS 345 is probably even a little taller.
Old 12-09-2011, 03:37 PM
  #63
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
ok .. .here's the deal if you want to be one of the first peopel to get the new sized PSS tires I will notify you directly as soon as I have the information
send an email to Luke@tirerck.com listing your name, phone number and sizes you want and I will add you to the list I have created for the PSS tires
Old 12-09-2011, 09:11 PM
  #64
jsilvz
jsilvz's Avatar
Thanks Luke
Old 12-09-2011, 09:47 PM
  #65
Tsar
Tsar's Avatar
Originally Posted by eagle0001
Great news! I just called Michelin to see if a Pilot Super Sport 345/30ZR19 is in development and was told this it is!
No word on availability; however, at least it's in the works. I hope my GY run craps can hold up for a little longer until the PSS 345/30ZR19 is available. I hope! I hope! I hope!
Forgive my ignorance, but does that size fit the stock wheel with no issues (rubbing)?
Old 12-10-2011, 12:30 PM
  #66
dvandentop
dvandentop's Avatar
count me in luke for z06 sizes
Old 12-10-2011, 12:40 PM
  #67
Frenchican
Frenchican's Avatar
Old 12-10-2011, 02:35 PM
  #68
Undy
Undy's Avatar
yes
Old 12-27-2011, 11:43 PM
  #69
Memphomaniac
Memphomaniac's Avatar
Email sent for the 325 and 345 widths - thanks Luke!
Old 12-28-2011, 11:54 AM
  #70
08VRZ06
08VRZ06's Avatar
Cruise-In X Veteran
These are the Michelins that I am running on my Z06 now.
http://www.tirerack.com/tires/tires....oModClar=SRT10 Coupe
I have over 12,000 miles on them and still have 5/32 of tread. They are also very good in the rain as well as on dry pavement.
Mark
Old 01-07-2012, 11:39 PM
  #71
MrGary2011
MrGary2011's Avatar
I may be going overkill on my 98 vert! I am going to 18/19 inch wheels and need a new set of tires and after all the reviews decided these were the ones to get! The C5 guys don't even mention them. I am waiting for my rear set to get here and in the spring will be hitting the road! I am very excited to see how these tires perform.
Old 01-07-2012, 11:44 PM
  #72
AzDave47
AzDave47's Avatar
You realize the PSS in either the 345 or 325 size won't be available until mid-Feb., so you must have gotten the PS2's? Of course, those sizes are probably too wide for your C5.
Old 01-08-2012, 09:02 AM
  #73
MrGary2011
MrGary2011's Avatar
For the rear I purchased 275/35ZR19 (100Y) for 19 x 10 wheels, fronts are 245/40ZR18 (97Y) for 18 x 9.5 They are the Pilot Super Sports from TireCrawler.com
You don't think these will fit? They are in the garage and havent put them on yet, these were the recomended sizes.
I will be a bit upset if they dont fit!
Old 01-08-2012, 09:40 AM
  #74
AzDave47
AzDave47's Avatar
I was concerned with 345 or 345 not fitting as those are the sizes discussed on this C6 Z06 chat board. The sizes you got should work on the C5. Don't worry, be happy.
Old 01-14-2012, 10:57 AM
  #75
timmyZ06
timmyZ06's Avatar
email sent luke!
Old 01-29-2012, 08:26 AM
  #76
Undy
Undy's Avatar
Default They're in production now!!!!
I talked to Michelin last Thursday and they told me the new tires are already in production! They will be hitting the distributors starting the 1st of February. I'm #2 to receive a set on Luke@tirerack's "super sport" tire list. They'll be replacing my 30K mile+ non-runflat PS2s.
Old 01-29-2012, 10:43 AM
  #77
dvandentop
dvandentop's Avatar
awesome!! i wonder when some of the other sizes will be hitting the rack then as well
To Michelin Pilot Super Sport 345/30ZR19
Old 01-29-2012, 10:46 AM
  #78
dvandentop
dvandentop's Avatar
Originally Posted by Poor-sha
Still no rears for the CTS-V. Bummer as I'm going to need new tires when I take the Winters off in the Spring.
hope these make it for the v in this latest batch
Old 01-29-2012, 03:15 PM
  #79
Translator
Translator's Avatar
What is the difference between these tires and the PS2's? On stock sized Z06 Rims, will the 345's bulge? Do they make matching 295's 18's for the front? Does anyone have pricing information?
Old 01-29-2012, 05:04 PM
  #80
AzDave47
AzDave47's Avatar
Higher tread wear rating (300 vs PS2 220), more grip, but non-runflat. No pricing yet but comparable to PS2 non-run flat. No info yet on dimensions, but they are supposed to make 325/30-19 and 345/30- 19; 285/35-18 is the current widest 18.
Quick Reply: [Z06] Michelin Pilot Super Sport 345/30ZR19
