C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Question about HP to weight
Old 04-05-2011, 05:40 PM
starchedup
starchedup's Avatar
Default Question about HP to weight
I was told (on a C6) you'd need 100hp per 100lbs to equal the performance of a Z.
IE. The normal C6 is about 200lbs heavier than a Z. Would a C6 need 650rwhp to equal the acceleration (keep up with) a Z putting down 450hp?
How would my 608rwhp Z compare against a super charged C6 putting down 900rwhp? How badly would I get walked?
Be happy to know just how much weight plays into the acceleration formula for our cars.
Old 04-05-2011, 07:08 PM
haljensen
Support Corvetteforum!
haljensen's Avatar
Where did you get the info of 200#'s heavier? My 2008 C6 Coupe weighs aprx 3180# on scales and has 436HP. C6 Z06 are usually rated at 3160#'s and 505 HP.
505HP - 436HP = 69HP. So add 69HP to an LS3 for comparable HP/Weight. Gearing and tires will make a small difference but a 500 HP C6 should run right with a C6 Z06.
Old 04-05-2011, 08:30 PM
harrydirty
harrydirty's Avatar
Spec weight for 2008 coupe is 3217......so maybe the scales are off?
Old 04-05-2011, 08:47 PM
LTVN68
LTVN68's Avatar
My ZO6. 505HP / 3160lbs = 0.1598 HP per pound
6.25 pounds per HP
My Honda CBR1000rr ABS, sportbike. 182HP / 435lbs = 0.4183 HP per pound
2.39 pounds per HP
No wonder the CBR wants to do 0-60 in under three seconds.
Let me reassure you, however, that I consider the ZO6 the best of the best! I just had not thought to do this calculation before and found it interesting.
Old 04-05-2011, 08:58 PM
Carnac
Carnac's Avatar
Pounds per HP will give you a good idea until higher end aerodynamics come into play (say above 140 mph).
Z06 at 3160 / 505 = 6.25 lb/hp
C6 coupe at 3208 / 436 = 7.36 lb/hp
C6 GS at 3310 / 436 = 7.59 lb/hp
ZR1 at 3333 / 638 = 5.22 lb/hp
C6 convertible GS 3289 / 400 = 8.22 lb/hp
On similar vehicles, pounds/horsepower is a good indicator of performance. Compare either rear wheel hp or engine hp - just compare the same (easiest to compare engine hp since that is what is given as spec by the manufacturer).
To get similar lb/hp in a coupe vs the Z06 you would need about 513 hp (or about an additional 77 hp). This of course assumes similar aero, however the coupe has better aero than the Z06, but the Z06 has better traction (bigger tires). Gearing makes a difference also. Finally, on a road course the handling is different for the different versions of Corvette.
Jim
Old 04-05-2011, 09:12 PM
thebrander
thebrander's Avatar
Jim
Agreed on the peak HP analysis, but my guess is the real difference between an LS3 and LS7 vette performance is the area under the torque curve. I suppose you could take the LS7 torque curve and scale it by "3208/3160" and point to that curve as the curve required for the modded LS3 to match or exceed. You'd have to also correct for the different redlines. Not sure though. Reality is always more complicated than crazy math.
Old 04-05-2011, 09:15 PM
thebrander
thebrander's Avatar
That's an impressively lite C6 Coupe. Is it stock?
Old 04-06-2011, 12:27 AM
Garrett W
Garrett W's Avatar
That's the dumbest thing I have ever heard. Do the math and it proves that isn't true...
Old 04-06-2011, 12:50 AM
paisa427
paisa427's Avatar
Its not 100hp for every 100lbs of additional weight , its more or less, 10hp for every 100lbs.
Vette5.5
Vette5.5's Avatar
As already mentioned, there's other factor's that come into play. First off, a base C6 is only about 100lbs more than a ZO6, and you're not needing 605 hp to stay even. Factor in the ZO6's larger torque, but more aerodynamic drag. A blower on a smaller engine tackles the torque, but add's more weight and other problem's if not properly done. Guess it's easy to see, there's really no cut and dry formula, especially if you're doing some road course tracking.
Old 04-06-2011, 10:16 AM
LEAVINU
LEAVINU's Avatar
No idea where you heard that from or even how that could possibly have any truth to it.
That's about right for a 1LT car while a 3LT will be closer to 3300lbs which is where mine started out at.
Old 04-06-2011, 11:26 AM
starchedup
starchedup's Avatar
Yeah I thought the C6 was about 33xxlbs but it looks like its only 3215lbs. http://www.roadandtrack.com/tests/up...ette-coupe-z51
So gearing makes a difference too... Did I read this article right, the Z-51 has a 2:73 rear end? What is it on the Z?
Old 04-06-2011, 02:01 PM
LEAVINU
LEAVINU's Avatar
The Z51 cars have a shorter gear (same as C5Z cars) which would make their shifts shorter 1-4.
Yes, it does look like the auto Z51 car has a 2.73 but the manual is a 3.42 still. The base C6 has the same gearing as a C6Z just shorter redline (6500 vs 7100).
Old 04-06-2011, 02:25 PM
starchedup
starchedup's Avatar
Thanks for clarifying.
Old 04-06-2011, 02:50 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I still go by the rule of thumb I remember from 50 years ago.
10 HP = 100 lbs.
10 HP = .1 sec in 1/4 mile
100 lbs = .1 sec in 1/4 mile
So, if a C6 weighed 100 lbs more then a Z06 it would need the horsepower difference(69 HP) + another 10 HP to make them equal in acceleration.
Old 04-06-2011, 02:56 PM
PhysiPhile
PhysiPhile's Avatar
Wouldn't more weight actually increase acceleration until a certain MPH by increasing friction force (u*normal)? I have to reduce power to limit slipping under 50 MPH. I'd like to see more data on max force without slipping considering various factors like temperature and road surface. I've noticed on smoother roads, I slide even when I'm barely accelerating from a light while on the highway I can nail it at 4k RPMS without slipping.
Old 04-06-2011, 04:52 PM
GMuffley
GMuffley's Avatar
To Question about HP to weight
Quick Reply: [Z06] Question about HP to weight
