C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Stumbling at low rpms, erratic idle, loss of high RPM power
Old 05-01-2011, 10:25 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Originally Posted by Geared
joe,
i doubt he turned it off, but its possible....i used a cheap scan tool that may not have properly read the computer - it was the loan a tool scanner from advance auto parts
jb
If you have a big cam, sometimes tuners turn off this code as a lopey idle can sometimes set the code.
Glad you're back running well
Old 05-01-2011, 11:41 PM
Geared
Support Corvetteforum!
Geared's Avatar
no cam.
thanks for all the help
Old 05-02-2011, 02:41 AM
Luweegy
Luweegy's Avatar
I found this.....could this be the culprit, and cause the about described symptoms?
Spark plug wires boot, driver side was laying on header (like alot of people) and while trying to diagnose this issue, I had the car running....and
a small spark occured when I lightly lifted that wire (it touched header)...and I came to find out the boot is cracked.
Could this be it?
How could this cause a near 50% power drop all of a sudden at high rpm?
That looks like the problm rt there.I'll bet there is more than 1 wire that is doing that.
Old 05-02-2011, 03:06 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Very glad to see that you figured it out! Congrats!
Thanks for the photos too, they help to get an idea of what you were looking at.
Brent
GM Customer Service
Old 05-02-2011, 03:48 PM
C5 Frank
C5 Frank's Avatar
Glad you figured it out! I had a hunch it would be something like that. Definately look at all the other wires carefully too.
Old 05-02-2011, 06:31 PM
Geared
Geared's Avatar
No other wires come close to the header. This one was literally resting on the header tube.
Quick Reply: [Z06] Stumbling at low rpms, erratic idle, loss of high RPM power
