[Z06] Katech 116 torquer cam
I've installed one for a customer and I liked it a lot. Car had a nice lope at idle but nothing crazy and still had stock drivability and that was without a tune. I'll need to dig up the numbers he put down I can't remember.
Its probably the cam I'll put in my car.
Im also very curious about this cam. Id like to hear from current owners that have this cam and also from jason too.
Supporting Vendor
St. Jude Donor '09
Yep. 594 RWHP/568lbs-ft torque. It is the best overall street grind in my opinion.
I have seen folks get close to the sweet idle quality I have but nothing beats this profile with high compression for the street.
I'll do an idle video tomorrow.
Jim Hall
Jim Hall
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
WOW that is amazing!!!!!! What other supporting mods if you don't mid sharing??
Oh come on now, those numbers a LITTLE misleading. You toss a 116 Torquer into a car with cleaned up heads, a 102/102 and catted LTs running 93, you're not going to be anywhere near those numbers.
This is mine using a Torquer on a 114/full bolt on/pump (93)
Premium Supporting Vendor
St. Jude Donor '08-'09-'10
Jason:
I really like the 110. Question I have is wouldn't the 110+4 start to nose over more in the upper rpm range than the 116? The graph makes it look like the 110+4 just continues to carry power regardless of rpm.
Other than LSA and ICL, these cams are the same lift/duration/lobes correct?
Jason:
Correct. The only difference between the Torquer 110 and the Torquer 116 is the lobe timing. Duration and lift are the same.
DJ I think you have the best looking engine bay on the forum, the exact look that I plan to go with.
Agreed, but giving those results without adding "but I'm running 13:1 compression and E85" is akin to saying "I'm making 550whp with a .562/.558 211/230 cam" without mentioning that its in an LS9.
