C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Door won't open 08/z06
Old 06-13-2011, 09:02 AM
LiviusSteven
LiviusSteven's Avatar
Default Door won't open 08/z06
i,m having a problem getting into my car. Sometime the door will open sometime it won't. When i grab the door opener the window will come down just a little (like it should) but the door won't open...
all the other doors will work, including the trunk
anyone else had this problem?
Old 06-13-2011, 09:09 AM
rrpederson
rrpederson's Avatar
Happens to me on occasion on my 07, I need to replace it. From what I researched, the problem is most likely a bad door switch. Its underneath the rubber pad and is kinda of like a circuit board. I think gm parts warehouse has them for like 14 bux. They are easy to replace. Two screws and the whole black door handle slides out. You could try removing yours (carefully) and cleaning. Good luck.
Richie
Old 06-14-2011, 05:05 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
I see rrpederson offered some advice to you… will you let us know if that is helpful to you?
Thanks,
Laura
Chevrolet Customer Service
Old 06-14-2011, 05:55 PM
jstahl
jstahl's Avatar
There is a TSB for 2008 models having switches with the part # beginning with a 1xxxx. If one fails GM has advised the tech to replace both L&R switches. This is assuming your car is still under the 3/36. Otherwise it's on your dime
Old 06-15-2011, 12:07 AM
y2kvette
y2kvette's Avatar
i'm getting new door handles for my '08 also, window would repeat index up, down, up, down till i squeezed the driver door handle just right. There was a bad batch of handles i assume.
Old 06-15-2011, 03:09 PM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Bingo, that's the problem and fix.
To Door won't open 08/z06
Quick Reply: [Z06] Door won't open 08/z06
