[Z06] Swapping the T56 for a TR6060, is it drag and drop?
I'm having my T56 swapped for a TR6060, but I would like to know if the TR6060 has any additional sensors or can it just be swapped with the TR6060 as if it were being replaced with another T56?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
EDIT: The 08 TR6060 is a direct bolt on to your Z06. All the sensors will be direct plug in also.
Is2scooby (01-21-2016)
Supporting Vendor
The 06 up diff are the same so it wouldn't matter. You can swap the 08 up trans/diff to 06-07 Z06 as a drop in. The external dimensions are the same.
You will like the upgarde
I just did mine shifts better and is a much stronger transmission. I went with carbon blockers and it makes no noise even cold. Rick at RTK56 just did mine. It was a direct bolt in from my 2006 Z06.
you know Rick I just noticed that this was posted in the C6 forums lol I was meaning it for this trans and diff to fit a C5.
No, it is not a direct swap. You need the complete z06 rear end, and other parts.
Was there a change from the early difs to the 09 or am I just looking at the DIY pics wrong?
Supporting Vendor
Rick, I know you give great info on the forum. On my 09 Z06 the dif lower drain, which is also the lower dif cooler line comes out the back of the dif and will not come out all the way as it interferes with the cradle. On the Z06 DIY dif oil change, the pics show that line coming out the bottom of the dif.
I just did the swap in my 06 z06. RKT built the tranny. Rick is a awesome person to deal with. He listens to what you have to say compared to another company. They just ask you a few questions and go this is the tranny and costs. Thanks bye. My clutch is a little noisy in neutral. I also have solid mounts. It grinds a little when its cold from 1st to 2nd but it feels solid as hell and can take a beating. I also have the zr1 5th and 6th gear upgrade. Damn thing even pulls hard in 6th...
Supporting Vendor
