C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Motortrend tests the 2012 Z06(video)
Old 08-04-2011, 12:58 AM
  #41
ivanjo11
ivanjo11's Avatar
Originally Posted by C5 Frank
The handling and braking test numbers are simply amazing!!!
What a difference those tires make..No wonder why this car did 7:22 at the Ring.
Another interesting change the weight distribution is now 49/51 how GM put more weight at the rear? i don't know..
Old 08-04-2011, 07:39 AM
  #42
jschindler
jschindler's Avatar
Maybe the took some weight off the front (like the Carbon Fiber hood).
Old 08-04-2011, 07:44 AM
  #43
jschindler
jschindler's Avatar
Originally Posted by clevay
The 11.9 sec 122 mph trap speeds are understandable considering how heavy the Z06 has become since the 06/07 model years. The 06' ran 11.6-11.7 at 125-126 MPH at around 3150 lbs bone stock. At 105K the 2012 Z07 has become heavier, and appears to be more refined and easier to drive. It is also slower in my opinion. Put the Z07 suspension package and tires on a 06' Z06 at 3150 lbs and see what the numbers look like.
They will look like ZR1 numbers and that is exactly what GM does not want you to see. Now the performance between the 2 have become blurred and that's just not good for business. Don't believe the hype.
The weight hasn't gone up enough to drop the trap speed 5mph. Anyone with any real drag racing experience understands that the driver and conditions can make that much difference in identical cars. I pointed it out before - the test in the video here was at an airport - and it undoubtedly used some sort of electronic "G-Force" type of measuring device for the times. How did they stage the car? How was the track prepped? What was the ambient temperature? What was the altitude? Did they posted corrected or uncorrected times?
It's not about believing the hype. GM can't help that people on forums don't understand that you cannot compare 1/4 mile times from totally different sources.
Old 08-04-2011, 08:32 AM
  #44
jmc5
jmc5's Avatar
Originally Posted by 95jersey
Your only flaw here is you are comparing OEM to OEM. OEM pads are meant for the street and are junk for the track. I agree the OEM Z07 are better, than the stockers, but JUST LIKE THE CONCEPT I USED FOR THE TIRES, I can go out and get true set of race pads (Wilwood H, Hawk DT-70's, Carbotech XP16's) and with Hoosier out brake a Z07 all day long.
You say blasphemy?!?! This guy is crazy??? GM spent millions designing this thing!!!!
The Z06 with Z07 package with professional test drivers in 2011 lapped VIR (Virginia International Raceway) at 2:53.5. To give you an idea the LP640-4 SV did it in 2:53.9 and 430 Scuderia in 2:54.6
As of now the SCCA T1 LAP RECORD (SCCA showroom stock Touring One class) Amatuer race class which is made of up 90% Corvette's (no Z06's or ZR1's allowed, just base C6Z51 and C5Z06's) is...hold on to your pants 2:01.24. That is a base Z51 with a T1 suspension kit and a set of Hoosier A6's (standard Iron brakes with Hawk DT-70 pads) and an amatuer race driver.
I love what GM has done with the car, but after you get to a certian point, it all becomes just for browny points and the REALLY fast track guys know what to use.
Come on man, if you are experienced, you should know thats too big a gap. Yes, real race cars are faster than all the factory optioned stuff, but not THAT much faster. You might sell me on 10 seconds a lap faster. Maybe 20, comparing the best race drivers in the best prepared cars versus a magazine driver in a car they don't own.
But 2:5x vs 2:01 ? No way.
Also, you should give the PSC's a try. They're pretty amazing. They are more expensive, but tirerack shows:
345/30ZR19 PSC @ $583
345/30ZR19 A6 / R6 @ $423
You can actually drive to an HPDE on the PSC. Street driving with Hoosier's is likely to leave you stranded with a flat. The new Z07 PSC's are actually runflats!
Also, the Z07 brakes probably aren't up to race duty, but you can drive to the track on them, and they'll work pretty well at the track and get you home without machining the rotors in half when they are cold.
These things are about compromises.
A real race car is trading off all the street niceties for track performance. Max bang for the $$, and who cares how it behaves on the street.
Some of the things coming out on the factory cars now are trading $$$ for very good performance at the track and still retaining good street manners.
Old 08-04-2011, 08:56 AM
  #45
agentf1
agentf1's Avatar
St. Jude Donor '10
Originally Posted by whatcop?
60mph at the top of 2nd? lol
Whatcop, could you please explain your sig pic to me. I am confused.
Old 08-04-2011, 09:43 AM
  #46
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Taped up the whole car for road atlanta as a joke and then during the drivers meeting my friends had their way with some duck tape over the painters tape.
http://forums.corvetteforum.com/c6-z...inks-so-3.html
Old 08-04-2011, 11:07 AM
  #47
95jersey
95jersey's Avatar
I looked up both SCCA and NASA lap records, and they both say FULL COURSE. Now you may be correct, I agree that is a dramatic difference, but the T1 guys have been know to do some amazing things. I guess what is the definition of full course?!@?
Old 08-04-2011, 05:15 PM
  #48
ivanjo11
ivanjo11's Avatar
Yeah maybe is that. I remember that the 06 Z06 weight distribution was 51/49 and its curb weight was 3,132 lbs
Old 08-04-2011, 05:27 PM
  #49
Liquid1
Liquid1's Avatar
Here is the deal on this whole thing, at least my take (coming from a driving school instructor).
You'll NEVER be able to take advantage of these tires on the street. If you are at the point where you are maxing these tires on the street, one of 2 things will happen:
1) You will go directly to jail and lose your liscense indefinately
2) You could kill yourself or worse someone else.
Doesn't everyone understand, these tires are a marketing gimmick to give the last C6Z lap times so it ups it's reputation in the magazine numbers game. Real life, they are a waste of time on the street and track. They wear too fast and you will never be able to take advantage of the grip they provide on the street (no matter what you think). On the track, they are nothing but overpriced R compounds, and Hoosiers will smoke them lap time wise for 1/2 the price.
The unfortunate part is this version Z06 was built specifically for the track, but EVERYONE who ACTUALLY does track days knows you just buy a standard Z06 and put some Hoosiers on it for 1/3rd the price. You don't waste time with carbon brakes and OEM pilot cups unless you have money to burn. A stock Z06 with a set of Hoosiers will be as fast or faster. So you buy a regular Z06, get an extra set of rims and switch between track/street.
I could see how the "general public" could see this as an awesome package, but if you do what this package is intended for (track days), you will find, you are better served with a stock Z06 and a set of Hoosiers.
Great post, I fully agree. As someone who tracks their car, I have no tolerance for jackasses driving recklessly on the street. You should have seen the look on my face when some jackass showed up at a car show with his teen daughter in a Ford GT on Hoosiers saying he's driven on them on the street in the rain and it's no problem. A leading contender to the next inductee to www.wreckedexotics.com, plus potentially putting his own daughter's safety in jeopardy.
Old 08-04-2011, 11:29 PM
  #50
clevay
clevay's Avatar
Sounds like you are making a lot of excuses here. Driver, conditions, G-Force electronic measuring advice. Look at the trap speeds and model year from the bone stock fast list;
The C6 Z06 Fast List
Last Updated: May 9, 2011
Bone-Stock on Stock Tires
Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details Thread Video
1~~~~ 10.981 128.90 1.77 Jamie Furman~ 2006 details~~ thread
2~~~~ 11.025 127.25 1.70 Ranger ~~~~~ 2006 details~~ thread video
3~~~~ 11.177 127.08 1.79 walterm32~~~ 2008 details~~ thread
4~~~~ 11.242 122.38 1.68 Dr.Ron ~~~~~ 2006 details~~ thread
5~~~~ 11.311 122.89 1.80 BLU-BY-U ~~~ 2006 details~~ thread
6~~~~ 11.349 124.97 1.75 zosix427 ~~~~ 2006 details~~
7~~~~ 11.392 124.84 1.92 C5 Frank ~~~~ 2006 details~~ thread
8~~~~ 11.429 124.88 1.86 dgdoc ~~~~~~ 2006 details~~ thread video
9~~~~ 11.443 125.93 1.95 O7zeeO6 ~~~~ 2007 details~~ thread
10~~~ 11.458 124.13 1.80 layjzay~~~~~~ 2006 details~~
11 thru 15 look pretty much the same way. Yes weight (i.e. 200 lbs) makes a huge straight line difference in trap speed alone. Now strap on the Z07 tires, brakes, suspension, and active handling on a 06/07' C6Z, put it on a road course, and see what difference these 200 lbs make. And yes, I have drag racing experience. Looks like you ride a motorcycle
Old 08-05-2011, 01:49 AM
  #51
Fritz Hier
Fritz Hier's Avatar
Originally Posted by NHRA95
At 3320 lbs curb weight, it's becoming a PORKER!
You read my mind.
Quick Reply: [Z06] Motortrend tests the 2012 Z06(video)
