[Z06] LS7 water pump flow number at 7000 RPM
Hi, like title said, anyone know the flowing number of the stock LS7 water pump ?
I'm planning to do 1.5 miles - 2,0 miles WOT top speed run, and I'm wondering if my Meziere EWP 55GPM are enough , or I'll get better flowing number with my stock one.
Thank you,
Seb
Thank you,
Seb
Also not sure if you've got a NW102TB, but if you do, be prepared to do a lot of filing/machining if you want to run it with the Meziere.
Cheers, Paul.
From my experience with the Meziere I would NOT recommend it for even ONE full mile, never mind more, at WOT. I seem to recall something about the stock water pump flowing 55GPM at around 4000rpm. Also, Katech says the Meziere will only flow 55GPM if it's running into an open bucket. Although without knowing how the flow of the stock waterpump is measured, I'm not so sure how valuable Katech's info about the Meziere is.
Cheers, Paul.
Cheers, Paul.
So regarding the water pump, if I'm doing top speed run, I must reinstall the stock one , I'm right ?
Thank you sir !!
Seb
Paul, I run the NW102 old style TB with the meziere. and no machining grinding are needed. Just to install the TB upside down. The little black motor on the alternator side !!! Fit like a glove, Hope this help.
Thank you sir !!
Seb
Thank you sir !!
Seb
Interesting, I never thought to try mounting the NW102TB upside down...I figured that would make the fuel run the wrong direction
Cheers, Paul.
Jim
Cheers, Paul.
Cheers, Paul.
You say from your experience you would not reccomend the Meziere at even a mile.
Can you explain what you meant by this?
The stock pump will out flow the meziere at that RPM(7000), but once you come back to idle the meziere will out flow the stock pump. For sustained RPM runs a mechanical pump would be a better option.
My fear would be in a mile+ run that towards the end of it you might end up with enough heat that the ECM would start to pull timing at exactly the point where you needed the HP the most. Remember the OP's question stated he was going to do 1.5 - 2.0 mile runs.
Cheers, Paul.
