[Z06] Ragin Racin's new LS7 Sleeper cam!!
Supporting Vendor
Introducing Ragin Racin's new LS7 Sleeper cam. Absolutely STOCK drivability with increadable torque and power. Cam has just a slight exhaust sound, Truely a sleeper cam!!
22x 24x 114lsa
07 Z06
Stage 4
LG 1 3/4 super long tube headers
Ported Fast 102 intake
NW 102 TB
Ragin Racin Sleeper cam
Ragin Racin ported heads
Honker CAI
Pfadt inverted shocks
video: http://youtu.be/4IRedQqmoYg
22x 24x 114lsa
07 Z06
Stage 4
NW 102 TB
Honker CAI
__________________
RAGIN’ RACIN’
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
RAGIN’ RACIN’
Randy Leger
337-278-8397
More proof that less sometimes means more. Quite a split there extending the past peak power. Nice curve, very impressive. Couple questions....
This is with your ported head, correct? I'm assuming you came up with this grind to work with the ported heads?
Don't suppose you'll divulge the lift or lobe or who grinds your cams?
Do you CNC in house or send them out?
Supporting Vendor
It is our ported heads.
660 lift on intake and exhaust
Ragin Racin cam grind
Cam will work great with standard LS7 heads also.
This combination works extremely well together to make a 550+ hp car that is totally a perfect driver.
Also, when I see a vendor claim to have a cam for a street car and details are provided which indicate potentially no overlap I'm far more inclined to see credibility compared to one who claims something similar of a cam which I need to find out through other sources, has 29 degrees of overlap! O course I'm only speaking figuratively.
Cheers, Paul.
22x 24x 114lsa
07 Z06
Stage 4
NW 102 TB
Honker CAI
22x 24x 114lsa
07 Z06
Stage 4
NW 102 TB
Honker CAI
Hey Randy, I can no longer see prices for your LS7 packages on raginracin.com. Would this cam fall under an option in your stage 3 package? if so what would pricing be and availability for install?
Thanks,
Mike
Thanks,
Mike
I was at Ragin Racin during the dyno tune of this sleeper cam, the idle is very smooth almost stock sound but the HP and TQ numbers are tremendous, this combination is putting down some huge power!
Supporting Vendor
Supporting Vendor
Randy,
I have no doubt this cam is as good as you say and more. My experience with the lethal, punisher and striker was all . What was the compression? also, did you try it with bigger headers? I hate to ask this as i like to see videos of WOT rather than idling but since this is suppose to have stock idle like manners, do u think you can post a video of it idling?
Supporting Vendor
Wow, we've got exact lift, close to exact duration on intake and exhaust, as well as the exact LSA...so much for needing to keep your cam specs secret for fear of loosing "assets and investments"
Cheers, Paul.
Cheers, Paul.
I'm sure there are many cams close in numbers to this one. But to say you have the same exact cam when you don't even know What the Sleeper cam is. Oh well!! There are always some nay sayers in the crowd.
Supporting Vendor
Randy,
The compression is 11.8:1. The reason behind the 13/4 header was to build torque.
I have a couple of videos I will try to get posted today.
Supporting Vendor
It is available in a stage 3 also or just a cam package. Give me a call and we can discuss your options.
Incredible work from a very Credible tuner! After all the time I've spent with you in the shop, I know your integrity is second-to-none And I thought the Stalker Cam was good. Congrats Randy, on a remarkable setup!
I'll be seeing you soon for some more power on my ZR1
