[Z06] Brand NEW!! RPS "BC2" Billet Carbon Street Twin Clutch *PICS*
Former Vendor
Hey guys,
We are going to make someone a great Deal on This Brand NEW RPS BC2 Billet Carbon Twin Clutch Kit...We only have 1 of these left at this Special Price!!!
This Clutch will work in any C5 or C6 Corvette, it comes with the Extra Long Alignment Tool...
List Price $2495
ONLY 1 Left <<<Sale Price $1899>>>
The C6 Corvettes require a Bearing Adaptor...SPECIAL PRICE $85
RPS BC2 Billet Carbon Street Twin Clutch
We know you have heard about the RPS Street Twin for LS powered Corvettes, Camaro's and GTO's, but do you want a little more.? Is taking the car to the dragstrip, road course or even Spirited Street Driving your deal.? Well then the BC2 is the Clutch for YOU.. RPS is proud to introduce its all new BC2 Billet Carbon Street Twin Clutch with its “Strapless” lightweight billet clutch cover and billet pressure plate.. This design allows us to reduce the weight of the entire clutch and flywheel assembly to an incredible 32lbs with our billet steel flywheel.. The "BC2" use's our special flat finger diaphragm for smooth and predicable 7000 RPM plus shifts.. Our liberal use of Formula One inspired carbon-carbon friction material results in a lightweight clutch with unmatched long term durability.. This clutch is rated to 900rwhp. PLEASE NOTE THAT THIS CLUTCH IS FULLY REBUILDABLE!!!
We have everything else you need to do a Complete/Correct Clutch install in your LS Powered Vehicle!!!
WE Have IT ALL INstock at ALL time, SAME Day Shipping!!!
Eastcoast Performance is your ONE STOP SHOP!!!
Extra Special Deals on What you need...!!!
Please note:: Our New Clutch Bleeder kits are specificly made for Corvettes...
WE HAVE THE BEST BLEEDERS ON THE MARKET!!!
ECPC's NEW C5 Corvette Remote Clutch (one-man) SPEED-Bleeder Kit $59.99 w/Clutch Purchase
A 40" Stainless Braided Clear Teflon Coated Line!!
ECPC's NEW C6 Corvette Remote Clutch (one-man) SPEED-Bleeder Kit $69.99 w/Clutch Purchase
ECPC's Remote Clutch SPEED-Bleeder Protector $29.99 w/Bleeder Kit Purchase
2000 deg Thermo Heat Sleeve for your Bleeder Line
ARP Flywheel & Pressure Plate Bolts Both $59.99 w/Clutch Purchase
GM Flywheel & Pressure Plate Bolts $26.99 w/Clutch Purchase
Clutch Accessories Specials w/clutch purchase....
C5 Accessories....
GM 2004 C5 Z06 "Updated" Clutch Slave Unit $99.99
GM 2004 C5 Z06 "Updated" Clutch Master $89.99
GM C5 Z06 HD Throw-out Bearing $39.99
GM C5 Z06 HD Pilot Bearing $14.99
C6 Accessories...
GM C6 Clutch Slave $199.99
GM C6 Clutch Master $119.99
GM C6 LS2,3,7 HD Pilot Bearing $19.99
High-Performance Clutch Fluids
Motul RBF600 Clutch & Brake Fluid 16.90oz(500ml) $19.99
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (All 3 Bearings & Dust Shield) $199.99
10mm Input/Output Prop-Shaft Harden Coupler Bolts $7.99each
12mm Input/Output Prop-Shaft Harden Coupler Bolts $8.99each
PLEASE BE SURE & DONT BUY ANY So Called BMW OR EBAY COUPLERS, I GUARENTEE THEY ARE MADE IN CHINA or Taiwan!!!
Rubber Torque Tube Couplers
(the good ones, Our units have "Made In GERMANY" casted in the Rubber) German 10mm Rubber Couplers $99.99
(the good ones, Our units have "Made In GERMANY" casted in the Rubber) German 12mm Rubber Couplers $99.99
CARBON FIBER DRIVE/PROP SHAFTS on Special $999.99
*We have the 10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, These units we make are Truely* "BALANCED"
ECPC Billet Aluminum Balanced 10mm Couplers $129.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $139.99 each
We sell Mantic Clutches, RPS, ACT & our LS9zr6 and of course OEM LS6 & LS7 clutches...We average about 375 clutches per year...
Call Mike Yeager to place your order Mon-Sat 9am-7pm est...Sun 1pm-6pm est...1-864-404-1776...
Thanks for your interest..
We accept Visa, MC, Disc, Cashiers Check, Direct Deposit & Paypal..!!!
I had ordered some parts from Mike a few weeks ago, got them relatively quick. He does have his hands full and is a little overwhelmed due to lack of help at his shop.
