[Z06] Muffler Mod exhaust cracking problem
Muffler Mod exhaust cracking problem Updated APR 29 with Pics**
So I originally pulled my B&B Bullets and put on the C6Z exhaust with muffler mod done to loud pipe. Well 1 month later, it started rattling real bad, so I pulled the mufflers, cut them back open and saw the thin thin sheet of metal that the "loud pipe" goes thru on the inside, was completely cracked. So I attempted to weld it up. Well that only lasted about a week... What have other people been doing? I know this is a pretty common problem.
I have a4 post i used 2.5 tw a mig on lowest pieced in the gap bought new sheet metal for patches also took out 1/2 of insul. sounded great on dyno at 7000 so far so good new mods will tell
I might have to try that, did you cut out the old thin sheet metal or leave it? Do you have any pics?
muff mod
I am a elec. but ifound a 2.1/2 fencing pipe cut it lengthwise with milw.18v.metal circ. saw then 5.3/4 length 2pair 460 channellocks got em over perf.pipe squeezed shut cut apiece of same pipe to close gap welded it heavily didnt like cutout pieces so i bought steel and high temp black so far LOUD
Inlet side. If it happens to me. Ill have to cut between spot welds on other side. to weld some type of reinforcement ,22gauge and short beads .next try ill try .024 mig wire with mixed gas .Good luck axle backs may be in the cards for both of us.
Back at this again...
Has anyone ever basically remade the mufflers?
I am thinking about cutting the cover completely off, and replacing the two inside walls (on the quiet side seperater) with thicker sheet metal, and re welding it all back together. I really liked this setup, but can't deal with it breaking again.
I just got my car back and with headers and catless its so loud when i hit wild its startling and i wont be surprised if they selfdestruct but if they do ill cut opposite side first so final patching wont be difficult but im going with smaller wire for mig.I would gladly help you out ,not aware of your location.
Beware this might make some people mad... But i really like the loud side, wanted to retain the stock exhaust look, and making a whole new system was way beyond me. Now everyone can see what is inside the muffler.
Starting to open it up..
The rattling culprit this time..
What I decided to do, don't mind the mangled a$$ center section..it made me mad.
The place I went to went out of business, but I do know there is a forum member that comes down here regularly to do them for people, unfortunately I can't think of his name right now..
