C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Can Z06 hit 200mph??
Old 04-17-2012, 10:37 PM
9c1ny
9c1ny's Avatar
Default Can Z06 hit 200mph??
found this on youtube
Last edited by Vette_DD; 08-27-2012 at 04:20 PM. Reason: Illegal Activity on Public Road
9c1ny is offline
Old 04-18-2012, 01:14 AM
sublime1996525
sublime1996525's Avatar
Damn. IBFTL. I would live to try that some day.
sublime1996525 is offline
Old 04-18-2012, 01:25 AM
msd127
msd127's Avatar
crazy, thats suicidal at night
msd127 is offline
Old 04-18-2012, 09:42 AM
Screamin Z
Screamin Z's Avatar
What is top speed in 5th? I thought it was 198. He claims its stock.. Im calling BS
Screamin Z is offline
Old 04-18-2012, 09:55 AM
tim414
tim414's Avatar
St. Jude Donor '12
X2.....looks very fishy to me....notice the windshield....nothing changes....fake.
The Z06 in factory form only does 198....in 5th gear. That vid definitely is NOT real deal....
tim414 is offline
Old 04-18-2012, 10:06 AM
palindrome1H
palindrome1H's Avatar
What I never understand is why do people doing top speed tests always have the traction control off. I get turning it off from 0-100. I don't know about you but I would love traction control to save my butt incase I lost traction at 190+.
palindrome1H is offline
Old 04-18-2012, 10:15 AM
No4Play
No4Play's Avatar
did 183 in my bone stock 08 LS3 and still had wiggle room in 5th. This was at 3am with no traffic mind you. I don't mind taking a risk as long as it involves myself but when others are on the road it's a no-no.
No4Play is offline
Old 04-18-2012, 10:25 AM
66biskwik
66biskwik's Avatar
Here's a 660 Lingenfelter doing it. I doubt a stock Z06 would do it.
http://www.youtube.com/watch?v=5bU5yKVygKU
66biskwik is offline
Old 04-18-2012, 10:44 AM
jedblanks
jedblanks's Avatar
Would be fairly common for the speedo to show 200 at 198. That's only 1% off.
jedblanks is offline
Old 04-18-2012, 10:50 AM
GMuffley
GMuffley's Avatar
Ibtl
GMuffley is offline
Old 04-18-2012, 11:07 AM
FNBADAZ06
FNBADAZ06's Avatar
Just my observation on this Lingenfelter video......
I wonder what tire (or rear gear) this particular car has, as he's shifting at redline (?) at vehicle speeds that are well below what a stock tired, stock geared Z06 gets. He's shifting well before any of the MPH numbers I get in my car in each gear.
If he's running larger diameter wheels and tires than stock, he's actually going faster than his speedo shows if it wasn't corrected in the tune.
IMHO, I think a Z06 with a slightly taller tire and CAI with a shroud and ram-air modifications could pick up the additional 2 mph needed to hit 200 MPH.
FNBADAZ06 is offline
Old 04-18-2012, 11:16 AM
FNBADAZ06
FNBADAZ06's Avatar
If you put a slightly taller tire on the car, you can pull a few MPH more.
Stock Z06 hits 198 MPH on stock 325/30/19 rear tires at apprx. 6300 RPM...which is max HP. Put a CAI with shroud and some ram-air mods in place (ram-air does exist at these speeds), a slightly taller rear tire such as a 335 or 345, and pull 6300 RPM in 5th...you'll see an additonal 2 MPH, IMHO.
The car in the video says stock with CAI, but no mention of the rear tire size.
Old 04-18-2012, 11:26 AM
66biskwik
66biskwik's Avatar
Looks like he might be running a shorter gear, it's hard to tell with the camera jumping but by the sound it looks like he shifts at 50 in first
and 80 in 2nd. Also looks like he's shifting around 7400.
Old 04-18-2012, 11:30 AM
FNBADAZ06
FNBADAZ06's Avatar
He may be limited to 200 MPH ( LOL....limited ), but he's getting there mighty fast.....much faster than a stocker could
Old 04-18-2012, 11:53 AM
66biskwik
66biskwik's Avatar
Most 660's dyno in the low 570's rwh.
Old 04-18-2012, 06:33 PM
mark1107
mark1107's Avatar
St. Jude Donor '14-'15
Ibtl 2012 fellas!
It doesn't seem fake cause I looked closely at the windshield and I saw lights and cars passing on the opposite side of freeway. But he could be modded? I didn't think bone stck z's could do that....
Mark
mark1107 is offline
Old 04-18-2012, 06:59 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
It appeared he shifted into 5th at 157-158, which is normal(162 at 7000 RPM calculated speed)) and he did get it up to 200(hard to read with all the bouncing around). I would rather see a GPS readout vs a speedometer readout, for accuracy. GM says the Z06 will do 198. He did it. A slight head wind or a slight tail wind could make a couple of MPH difference either way. He seemed to be pulling pretty hard in 5th gear, though.
JoesC5 is offline
To Can Z06 hit 200mph??
Old 04-18-2012, 07:11 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,674 Likes on 1,067 Posts
Not sure what you're looking at. There are clearly lights moving. Look out the side window.
And from the looks of it he exceeded 200. The needle was past 200MPH (more like 209-210).
VetteVinnie is offline
Old 04-18-2012, 07:30 PM
Ruf-Racer
Ruf-Racer's Avatar
200 MPH " indicated" is way different that 200 MPH observed with a calibrated instrument.
I think I could go 200 MPH indicated if I spent some time lowering the CD ( drag) AND optimized the gears & tires.
Cheers,R
P.S.
Up to the 170 range the Z in the video sounds exactly like my old 07 Z06. Ran right up to about 170 then it crawled up the scale.
Thermal switch over temp warning (tranny)came on at about 65 miles running at an average speed of 160 mph.I ran with a cage & fire suppression system.
Ruf-Racer is offline
Old 04-18-2012, 09:13 PM
JoesC5
JoesC5's Avatar
Speedometer only goes up to 200 MPH on the C6.
JoesC5 is offline
Quick Reply: [Z06] Can Z06 hit 200mph??
