[Z06] missed shift and now no reverse?
I had missed a 4th gear to fifth gear shift the other day while out in the Z at about 6k rpm. I finished up my cruise and tried to back my car into the garage only to be shocked that my reverse does not engage? I can move the shifter easily in to the reverse position but when I let the clutch out nothing happens? I don't hear or feel any grinding, just a weird mechanical noise that sounds like something is free spinning and not engaging. Has anyone had this problem or have any idea what could be a possible fix? I find it hard to believe that a mis-shift can cause reverse to go out so easily. Thanks in advance.
1 Post
That is my idea of a nice cruise haha. I should of mentioned that,yes, I do have the TR-6060.
You have a PM.
Z//
The T56 in my 01Z was notorious about needing just the right amount of right wrist flick to upshift from 4th to 5th. On at least two occasions at freeway speed I couldn't get from the neutral gate into 5th. I let the shifter come back into center neutral and then I over did it with right hand flick and managed to rake Reverse. No ill effects ever happened over 49k miles from those misadventures. The 4th to 5th upshift is very easy with my 06Z and now 11ZR1. My experience has been that every 6-speed manual I have owned has had its own personality quirks.
Your idea of a cruise is the only way putting around at 65mph what's the point without some spirited blasts!!!
As far as the trans I would call RPM and have a conversation.
