[Z06] Sprayed it for the First time... 135mph trap in a 8500+DA!
Since I got my 10sec run N/A 2 weeks ago I decided its time to spray this thing. I only did 100-125shot.
car is untuned. all we did is pull 11deg off and thats all (I am at 10-11deg). 3sec delay. so nitrous only kicked in in 2nd gear. of course the car ran like crap in 1st gear since there is no timing in it at all. I didnt set up my window switch or LPE timing retard box so had to do it this way.
not the best shifting but wasnt that bad (I wasnt feeling very comfortable since its was my first time and I noticed i had a leak just before the run!) I think I even had it during the run because when I purged there was nothing coming out of the purge lines, but I def felt it in the car and I def was spraying. I am thinking it was really minor but I dont know I will check it later.
Car went 10.99@135 with a 1.76 60ft. I was running 1.5sec slower in the 1/8th than my N/A runs again due to no timing and not spraying in first gear. I picked up 8mph at the end. this was in a 8600DA. run looked nice and clean no knock (lol of course when pulling 11deg on just 125shot haha)
hopefully next week I will try to get the car tuned and have it ready. maybe do 250shot. we will see. I think I will start spraying in first gear next time because I dont know how I can not make it pull timing if the nitrous switch is on even with my LPE controller!? there is probably a way to do it but I will need to figure that out. I am thinking I will just do a 1sec delay so as soon as I launch it it will kick in. again I need to do some testing and keep adjusting because I am worried I wont have traction. we will see how it goes next week...
EDIT: forgot to mention that my vette is HEAVY for some reason. I am at 3470lbs with me in it. I understand that I have 4 bottles in the back and my roll bar but I also dont have my pass seat!! and I am only at 175lbs!!
Holy crap that diesel ran hard!
Yeah buddy!! Love the juice! Man your really pulling hard in 3rd and 4th. With that trap speed you'd think your 1/8th et would be low 6's. Get her dialed in so you can put that power to use. I still spray mine in 1st and it hooks on the Hoosiers.
Thanks I am not surprised about the 1/8 et. Because it does make sense. If you check my 10.9 run N/A you can see that I go through first faster. I mean really N/A with only 10-11deg of timing I am sure I'm down quite a bit on power so that's why. At least that's what I think. The spray kicks in not too far from the 1/8 mark. But yea I don't really know.
Excellent video, love the speed your running!! as far as traction control, do you totally disable, I'm not tryin to hijack your thread, just curious??also, are you spraying a stock LS7??? can I also spray my head/cam Z06??I'd love to, and what tires in the back are you running??again, fast mph!!!flying!!!
Thanks Yes that thing is freaking fast. I was actually surprised when I saw the slip. I have seen some fast Diesels here running Mid 10s!!!
It made 804whp SAE corrected with a 125shot when it was tuned. but we changed the timing box and installed a window switch along with few changes in the fuel and fuel pressure. we were at 15-16 deg of timing and had it a little leaner than now and it made 804. now we are only at 10deg, running a little more pressure in the stand alone. and switched from 112 to C16.
as far as traction, I only hit it once. which is traction control off only. I keep stability control on since it doesnt affect anything. actually it might save you in case you lose control. and no I have a forged 441ci darton sleeved LS7. its built to handle 400shot with no problems but I dont think I will ever go that far. its just too hard on things and I dont think I will ever be able to use it really! maybe 300shot but thats about it.
Yes you can spray your heads/cam Z06. all in the tune/tuner. also depends on your setup. but yes you can. what kind of fuel you are running?? compression?? is E85 or Race gas an option for you?? I am assuming you are on a stock fuel pump?? do you have bap?? depends on what kit you will run (Dry/Wet) you might need to upgrade your fuel system (most likely either injectors or add BAP)
I know some were in the 750whp range with a stock pump and BAP. I would def recommend you ask your tuner/builder or a rep shop in your area. maybe hit some of the vendors here. Personally I would go with only vette-air, RPM, or dallas performance. there is other good options out there (vette dr./LPE/IPS...etc) but thats just my preference.
I am running C5 Z06 rear 18" wheels w/ hoosiers drag radials 335/35/18 not the best but they are doing great!! I actually had problems with them beeing too sticky LOL so now I try to keep them around 18psi so that I dont have to launch it over 5500-5700RPM. If I take it down, it would bog on me at those RPMs. I know some are doing 6000-6500RPM but I dont feel comfortable doing that especially with my C5 z06 axles. I know they are great for what they are but I still dont feel very good about it. so I choose to run a little more air in them and just try to slip the clutch as much as possible and try to get a decent 60ft.
hope this helps... sorry I got carried away
Sounded great. If you can ride out that bog on launch, (maybe the juice in first gear will do it) and get the spray in all gears, she will be running bottom tens easy.
Car sounds mean! What cam is in your car?
Nice driving!
Nice driving!
yea I have been trying. I am not slipping the clutch enough. it should help if I spray it in first. I am thinking next time I will only do 1sec or 1.5sec. I will mess with it at the track and see what works best. my shifts didnt feel that great, especially shifting to forth, but in the vid it looks ok.
