[Z06] Post your LS7 Guide wear here - Master list
Date of heads pulled: 7/5/12
Head Type: GM LS7
Year: 2006
Miles: 16,000
Track time: None
Tune: Stock
Mods: Haltech M103 + B&B exhaust for maybe 6,000 miles. Just put headers on the car within 300 miles and have been easy on the throttle since no tune. Car is currently at Katech getting stage 2 and these were the specs of the guides.
Gauge Valve diameter .3135"
Guide Clearances
Intake #1
Top .0027
Mid .0021
Bot .0024
Intake #2
Top .0030
Mid .0022
Bot .0028
Intake #3
Top .0025
Mid .0022
Bot .0023
Intake #4
Top .0030
Mid .0023
Bot .0025
Intake #5
Top .0033
Mid .0022
Bot .0027
Intake #6
Top .0028
Mid .0022
Bot .0025
Intake #7
Top .0029
Mid .0023
Bot .0027
Intake #8
Top .0030
Mid .0023
Bot .0028
Exhaust #1
Top .0022
Mid .0026
Bot .0069
Exhaust #2
Top .0022
Mid .0024
Bot .0048
Exhaust #3
Top .0020
Mid .0028
Bot .0064
Exhaust #4
Top .0022
Mid .0024
Bot .0039
Exhaust #5
Top .0021
Mid .0029
Bot .0085
Exhaust #6
Top .0021
Mid .0023
Bot .0046
Exhaust #7
Top .0021
Mid .0024
Bot .0054
Exhaust #8
Top .0022
Mid .0025
Bot .0033
My observation, the exhaust valves on the left side of the engine (drivers side) 1,3,5,7 have more wear then the right side of the motor. Which makes me think oil could be a factor since that is the side furthest away from the oil sump. Regardless, every guide is out of spec on the bottom side.
Head Type: GM LS7
Year: 2006
Miles: 16,000
Track time: None
Tune: Stock
Guide Clearances
Intake #1
Top .0027
Mid .0021
Bot .0024
Intake #2
Top .0030
Mid .0022
Bot .0028
Intake #3
Top .0025
Mid .0022
Bot .0023
Intake #4
Top .0030
Mid .0023
Bot .0025
Intake #5
Top .0033
Mid .0022
Bot .0027
Intake #6
Top .0028
Mid .0022
Bot .0025
Intake #7
Top .0029
Mid .0023
Bot .0027
Intake #8
Top .0030
Mid .0023
Bot .0028
Exhaust #1
Top .0022
Mid .0026
Bot .0069
Exhaust #2
Top .0022
Mid .0024
Bot .0048
Exhaust #3
Top .0020
Mid .0028
Bot .0064
Exhaust #4
Top .0022
Mid .0024
Bot .0039
Exhaust #5
Top .0021
Mid .0029
Bot .0085
Exhaust #6
Top .0021
Mid .0023
Bot .0046
Exhaust #7
Top .0021
Mid .0024
Bot .0054
Exhaust #8
Top .0022
Mid .0025
Bot .0033
Received 8,928 Likes
What are you going to do about the excessive guide wear and how much more will it cost you?
Bill
Bill
Max allowable clearance is 0.0037 for both intake and exhaust
Replace the steel guides with bronze guides, replace the exhaust valves with OEM, and replace the intake valves with Katech's moly coated. They are giving me a 1 year 12,000 mile warranty so they are confident in this route. If you want my honest opinion, I wish I would have gone with an aftermarket set of heads like Mast or PRC to rule out the head all together as being the problem. With that said though, my observations about the driver side having more wear could be related to oil. The car was not tracked either so that's something that makes me wonder.
Also Cylinder #7 is usually the one that has the valve drop on these because of fueling/tuning right....well my #5 exhaust guide was worn out the worst. So to me I don't think it's a fueling issue when it comes to the wear, sure that can cause failure but I don't think it's related to the wear of the guides.
Last thing, I would really appreciate if people post their stats like I have above and we can make a long list!
Very last thing, I'm not a professional engine builder but I'm not a dumb either but just take everything I say with a grain of salt. It's just my opinion but the numbers I have posted are all accurate.
Bill
Bill
I had a tech bring up the specs for measuring valve guides and it has a picture of a gauge clamped to a rocker post, measuring from the top. Long story short, you can get the spec measurements with the heads on. I took a picture of it too because no one around here believes anything anyone says.... specs are <= .0037"
Bill
Date of heads pulled: 6/1/12
Head Type: GM LS7
Year: 2006
Miles: 18,000 (cam and mods done around 5,000)
Track time: None (90 1/4 passes)
Tune: Yes
Mods: Was a Katech stage 1 car (full exhaust, torquer 110 cam, halltec intake supporting mods etc) done at ~5,000 miles; was 531 rwhp then
Guys, just a thought. If you want this to be informative and helpful rather than the train wreck previous threads, keep your opinions about warranties and other things irrelevant to facts and data to a minimum. If you don't have data to assist here, don't feel the need to just fill the air...
All of mine were in spec from my understanding.
[IMG][/IMG]
Head Type: GM LS7
Year: 2006
Tune: Yes
[IMG][/IMG]
I'd like to bump this thread for other people to post their numbers. Keep in mind that the bottom of the guides are where most of the wear is showing up, not the top (for those of you who are trying to measure without taking your heads off).
If you look you're wear pattern, you will see that you have more wear in the middle than on the top.
That is a clear indication that you could have wear at the bottom of the guide.
In my case, because I'm a little pointed in this thresds, my middle measurement show no sign of wear and are equal on all cylinder.
This is just to be clear.
Thank you,
Date of heads pulled: 8/23/2012
Head Type: GM LS7
Year: 2007
Miles: 75,000 Engine and tune all stock
Track time: ~10 hrs at Sebring (~20 1/4 passes)
Tune: No
Mods: ZR1 clutch
Car always ate oil ~0.75-1 qt per 1000 miles with spirited driving (from 47K to 74 K miles), last two track days was more like 1+ qt per 100 track miles and smoking at start up (bad valve seals)
Last 3 days at Sebring had oil temps in the 240s to a max of 257 (IIRC) I'm a newbie at driving on a road course.
Valve guide wear: alot (not scientifically measured)
http://www.youtube.com/watch?v=Bi51kj51FvU&feature=plcp
The heads are being rebuilt right now, if I get numbers I'll post them.
Head Type: GM LS7
Year: 2007
Tune: No
Mods: ZR1 clutch
Head Type: GM LS7
Year: 2007
Tune: No
Mods: ZR1 clutch
Head Type: GM LS7
Year: 2007
Tune: No
Mods: ZR1 clutch
Thank for posting
Here is the Spec sheet on my heads. It is a 2008 and at around 24,000 miles it had a warranty cam and lifter replacement in May 2011. At 31,000 miles in March 2012 I decided to add headers and a Katech 110 cam and associated parts. I bought the car with about 15,000 miles on it. I wouldn't say that I drove it hard, a few 6K shifts, a few tire spins but no smoking burn outs and I never tracked it. When I installed the cam and changed out the springs, I noticed what I would say was excessive valve stem in guide play mainly on the exhaust valves. I put it together any way and drove it about a month (less than a 1000 miles) and decided not to take any chances and pulled the heads and have them checked and redone by WCCH. This sheet I got from Richard at WCCH and this is the exact measurements of all of my valve guides. As you can see some were worn very badly....... This engine was built Nov 29, 2007 and the Z06 build date is Dec 11, 2007.
Mark
Mark
