[Z06] Repair Method GY F1 (Gen1)
St. Jude Donor '12
I have had to remove one of my rear aftermarket wheels d/t a finish issue so I can send it back to them before the warranty expires.....
I have my factory (original Z06) wheels w/the original factory tires on them w/about 50-60% tread remaining.
When I pulled them down off my mezinine I found that one was flat and the other is low and has a nail in it (both rears).
What is the preferred method for repairing these tires? Plug? Patch? Plug AND patch....the Goodyear dealer in Denison Texas would not touch them.
I don't know whether to be happy or dumbfounded GoodYear will not/cannot repair their OWN tires. They told me they did not have a qualified guy to do this....???
Anyhow, I have brought the tires/wheels back to the city to get this done....I'm going to Discount Tire today to get this done....what should I expect...plug only or both....
I'm thinking both. thanks.
Depending on where the nail is determines if they will repair them. There is a specified distance from the side that a patch cannot be made in. I had the same issue with one of mine. If they are original as mine were they warrantied the tire and gave me another at pro rated cost depending in tread wear.
St. Jude Donor '12
The proper method is to patch them on the inside. I have plugged lots of tires without failure, but plugs can cause the tire to separate causing a bubble between the belt and tread. If you are just putting the tires on to ride around town they should be fine to plug. If you plan on going to the drag strip or going out for a "spirited" driving session, then I would patch.
Hope this helps
Hope this helps
^ What he said.
There are some Goodyear Dealers that won't work on these tires.
When I had a flat on my C5 Z06, I called around and found one of the dealers qualified to repair the tire. They did a good job. (Goodyear)
You could call America's Tire or any dealer that carries these to see if they could do it.
Good luck, 2k
Good luck, 2k
St. Jude Donor '12
^ What he said.
Good luck, 2k
Good luck, 2k
I do not understand why GoodYear cannot or would not repair their own tire...does it take a rocket scientist to dismount, repair and remount the tire....it's their business.
