C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Corner weighed the Z06 today
Old 08-04-2012, 06:46 PM
blkscls1z
blkscls1z's Avatar
Default Corner weighed the Z06 today
This was done with 1/4 tank of gas & 17" CCW rear wheels with 335/30 Hoosier drag radials. Not bad considering the Procharger.
Old 08-04-2012, 07:15 PM
crazed_z06
crazed_z06's Avatar
EDIT: Nevermind
Old 08-04-2012, 07:44 PM
forg0tmypen
forg0tmypen's Avatar
2lbs less and you are under 3,100. Bout time to ditch the windshield wipers.
Old 08-04-2012, 08:29 PM
Random84
Random84's Avatar
Or he could just drive out to lunch, get on it a few times, head back after he burned off a few pounds of fuel and get the 3,09Xlb photo.
Old 08-06-2012, 02:47 PM
Bedouin
Bedouin's Avatar
..or pull 1.5 gallons of coolant out of the tank & still have plenty of juice...
Old 08-06-2012, 02:54 PM
MitchAlsup
MitchAlsup's Avatar
Received 1,592 Likes on 784 Posts
The overall weight may not be so bad, but the cross weighting is WAY off. It is over 75 pounds off and should be under 25.
Old 08-06-2012, 04:18 PM
john_g_46
john_g_46's Avatar
I built a scale and installed four level pads on my garage floor (shot them in with a transit).
It's easy to adjust corner balance using the ride height bolts. Back them out to decrease force, run them in to increase force at a given corner. With my car up on four identical boxes sitting on the level pads (do not trust that your garage floor is flat) I use a floor jack and 2x4 to unload the spring. You can turn the ride height screws with your fingers this way.
Old 08-06-2012, 07:29 PM
torqjunkie
torqjunkie's Avatar
He said it was procharged, dont hey mount front right?
Old 08-06-2012, 10:13 PM
blkscls1z
blkscls1z's Avatar
Procharger sits on the right side. The scale reads left to right, not top to bottom.
Old 08-06-2012, 11:28 PM
OliverM5
OliverM5's Avatar
What other weight reductions have you done?
Old 08-07-2012, 02:22 AM
blkscls1z
blkscls1z's Avatar
CCW Rear drag setup and the Mcleod RXT saves some weight also.
To Corner weighed the Z06 today
Quick Reply: [Z06] Corner weighed the Z06 today
