2006 Z06 random misfire P0300 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Old 08-23-2012, 11:01 PM   #1
forg0tmypen
CF Senior Member
forg0tmypen's Avatar
Default 2006 Z06 random misfire P0300
Got a weird problem that has been happening off and on for the last year or so. My car will randomly start to misfire on occasion. It will run fine. No problems. Then, chug chug chug chugchug chug chug. It will smell like gas, and a flashing engine light will come on with a P0300 code. Plug wires are fine, coils are fine, spark plugs are fine. This happens very seldomly and will go away after the car has been off for a half hour or hour. Sometimes it will misfire while idling. This only happens once every 3 months or so and goes away after I start my car up again (sometimes it has to sit for a few minutes).
I also got a code for a small evap leak recently as well (gas cap) but after replacing the gas cap, everything seems to be fine. What are your theories guys?
Dirty injectors?
Could it be a small evap leak other than the gas cap?
Vacuum line got nicked?
What about a bad vacuum solenoid?
Or bad 02 sensors? No codes for this though.
Bad 02 senor harness wire?
Maybe it is a bad coil/plug wire/spark plug? Could that cause a P0300?
Bad MAF sensor?
Thanks for the input.
forg0tmypen is offline   Reply With Quote
Old 08-24-2012, 06:19 AM   #2
forg0tmypen
CF Senior Member
Bump
Old 08-25-2012, 04:30 PM   #3
forg0tmypen
CF Senior Member
Anyone?
Old 08-25-2012, 04:41 PM   #4
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Quote:
Originally Posted by forg0tmypen View Post
Anyone?
Just have them check that when you take it in for the other warranty work on the heads.
'06 Quicksilver Z06 is offline   Reply With Quote
Old 08-25-2012, 04:43 PM   #5
ZR-1 1991
CF Senior Member
Anyone?
#PIP3907: SES Light, Engine Misfire and Valvetrain Tick Noise - Inspect Valve Springs - keywords CEL crack DTC engine light MIL miss P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 rattle rough valvetrain - (Sep 7, 2006)
Subject:SES Light, Engine Misfire, and Valvetrain Tick Noise - Inspect Valve Springs
Models:2006-2007 Chevrolet Corvette Z06
with 7.0L Engine (VIN E - RPO LS7)
On rare occasions, a SES Light, engine misfire, and valvetrain tick noise may be experienced. Upon inspection, a P0300 - P0308 DTC may be stored. This may be the result of a broken valve spring.
ZR-1 1991 is offline   Reply With Quote
Old 08-25-2012, 06:45 PM   #6
forg0tmypen
CF Senior Member
Valve springs have been checked but well see.
Old 08-25-2012, 07:27 PM   #7
pokerpro
CF Senior Member
Support Corvetteforum!
C6 of Month Finalist 2015
pokerpro's Avatar
My first guess would be the MAF sensor.
pokerpro is offline   Reply With Quote
Old 08-25-2012, 07:54 PM   #8
forg0tmypen
CF Senior Member
Quote:
Well it was found that I have a rough idle. Could that be MAF sensor related? Another dealership question... Lol
Old 08-25-2012, 08:03 PM   #9
ZR-1 1991
CF Senior Member
It would be a different code.
Old 08-25-2012, 11:51 PM   #10
erikszr1
CF Senior Member
erikszr1's Avatar
i have repaired two 08 zo6s that had this same issue. it turned out to be the connections under fuse box to injector fuses. terminals were not seated/clicked into locked position. also i would check all grounds. hope this helps.
erikszr1 is offline   Reply With Quote
Old 08-26-2012, 10:01 AM   #11
forg0tmypen
CF Senior Member
Quote:
I'll check today. Which fuses are they?
Old 09-12-2012, 02:54 PM   #12
TORQJNKY
CF Senior Member
TORQJNKY's Avatar
Any luck on this? I've got the same random problem. Although the car never seems to run bad, chug or anything. I just get a random P0300 that will clear and not come back for weeks sometimes.
TORQJNKY is offline   Reply With Quote
Old 10-12-2012, 03:40 PM   #13
METERSF
CF Senior Member
METERSF's Avatar
where is this located exactly kind sir? thx
METERSF is offline   Reply With Quote
Old 11-14-2012, 09:30 AM   #14
forg0tmypen
CF Senior Member
Bump
Old 11-14-2012, 11:03 AM   #15
Sébast19X
CF Senior Member
Sébast19X's Avatar
Louis, start to clean the MAF, Then do a cylinder leak test.
Injectors cleaned . After that, if probleme are still there.
Inspect valve spring. And after that, check for item shipped
Hope this help
Seb
Sébast19X is offline   Reply With Quote
Old 11-14-2012, 11:12 AM   #16
z51vett
CF Senior Member
z51vett's Avatar
Check plug wires had one that was missing and tech at dealer could not find went out when it was cold checking plug wires #8 came off in my hand without hardly a tug. Put wire on end of problem the tech only hooked up the tech 2 tool showed misfire all over the place.
z51vett
z51vett is offline   Reply With Quote
Old 02-07-2013, 05:06 PM   #17
venom350gt
Junior Member
I had the same thing just happen and through a process of elimination I think I have found the problem. Seems to be a bad coil pack. I replaced the plugs and wires and the car runs better at idle prior to a mis-fire. With the mis-fire being inconsistant i know it could not be valves or springs, so i moved to the coil pack. Code was P0307 so cylinder 7 misfire. I switched the coil packs on cylinder 7 and cylinder 3. cleared the old code started it up and no MIL. drove it around the block and it threw a code to my delight P0303 = Misfire on cylinder 3 I FOUND MY PROBLEM. TAKE THAT STEALERSHIP!!!!
venom350gt is offline   Reply With Quote
Old 02-07-2013, 06:07 PM   #18
jwmgr8
CF Senior Member
Had a problem like that, turned out to be piece of crap over priced MSD coils. MSD even said they'd replace the coils but never did that was two years ago. every 2 months they would give me a story about manufacturing problems. I'll Never buy another MSD product.
Stock coils work great
jwmgr8 is offline   Reply With Quote
Old 02-07-2013, 08:37 PM   #19
venom350gt
Junior Member
ill remember that, thanks for the heads up
Old 02-27-2013, 06:04 PM   #20
forg0tmypen
CF Senior Member
Thanks for all the replies guys it didn't notify me that anyone had replied. I recently replaced most of the whole drivetrain so this shouldn't be a problem anymore, shop did an awesome job on everything and I suspect it should be cured. Knock wood!!
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 2006 Z06 random misfire P0300
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Engine misfire, got some codes, need advice WildRide357 C5 Tech 1 12-27-2016 01:44 PM
    P0300: Misfire from hell jwg2 C5 Tech 17 09-14-2015 11:16 AM
    Multiple Cylinder Misfire Code P0300 Help! SoCal LS2 C6 Tech/Performance 11 09-05-2015 05:12 PM
    Rough and won't idle Yellow Z C5 Tech 6 11-11-2012 08:54 PM
    LT4 check engine light blues pettsir C4 Tech/Performance 22 11-07-2004 10:46 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
