[Z06] Catch Can Contents
St. Jude Donor '12
Catch Can Contents
Emptied my catch can yesterday evening. It was first time in a year. The car had less than 3k miles since last emptied.
It contained 34 cc's of oil....I measured it. Filled the bottom fourth of a beer can. Only street miles. (there was a romp late last winter/early spring at say speeds of 145 + mph....and rpm to 6k).
Does anyone know which "street" conditions exists that cause this car to spit out that much oil in crankcase vapors?
Also, does anyone know if I could plump this directly back to sump tank?
BTW, it's a '10 Z06 w/11,400 on clock now, had since new.
Tim
Tim
Tim
Tim
The consensus over on the F150 forums, was that you don't want to reuse the contents of the catch can, so I don't know that you would want to plumb that back to your sump tank. I don't know if that's a good idea.
http://www.f150forum.com/f70/5-0l-oi...9/#post1387903
http://www.f150forum.com/f70/5-0l-oi...4/#post1131790
I would not reuse, as if no catch can the intent of the pcv system is to burn this off so seems to me a bad idea to put back in the oil system.
Oh, and how about driving the thing more often. Just 3k miles in a years time.
St. Jude Donor '12
I had them repaired but it's been so dam hot around here even the devil won't come around (avg 102 w/70% humidity-literal steam bath)
Otherwise, it would have 15k on it now as I do put 4-5k mi/yr on it and have had it now 2.5 going on 3 yrs now. And I can drive it 10-11 months/yr in these parts.
