C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] new mod PHOTOS -SharkBar, Caravaggio, Sparco
Old 10-26-2012, 12:41 AM
Mike.D
Mike.D's Avatar
Default new mod PHOTOS -SharkBar, Caravaggio, Sparco
D bottom, Shifter **** Alcantara. Arm rest leather with titanium stiching
The white gloves are Sparco's arrow H7's. They stick like GLUE to the alcantara!
John is very particular with his work. Fit and finish on these seats are amazing. I chose these seats over sparco's because 1. They look like G.M installed them, and 2. there are absolutely 0 codes, and EVERYTHING works (telescoping, airbag, and heated seats). http://www.caravaggiocorvettes.com/
The Sparco harness is all pro. Aircraft style cam lock. 2 inch shoulder straps for hans. the adjustment buckles are very easy to use. http://www.sparcousa.com.
The Special black duct tape professionally installed protects the plastic sills from scraping up . It will come off when I return from the track
SharkBar from VETTEWORKS. The finish on this bar matches the rest of the the interior. The service I got from Dan was fantastic. He took all 4 calls and 1 more on a Saturday evening helping me with some final installation questions.
The bar does away with those creeking sounds when driving over speed bumps. Even if you're not going to run a harness, this bar stiffens up the chassis. http://vetteworksonline.net/
The black 2 bar sliders are from Schroth ($2.50). Sparco did not have these with this kit.
Here's what I like best. The vetteworks Lap belt bar slides right under your 2 seat bolts and gets bolted in with the seat. After the track day, I just unclip all 4 belts and go to my stock belts
Old 10-26-2012, 02:57 AM
Hirohawa
Hirohawa's Avatar
Looks fantastic!
Old 10-26-2012, 04:49 AM
1981turbota
1981turbota's Avatar
Looks AWESOME!! If I come across some extra $$ I will give Caravaggio a call....:drool:
Old 10-26-2012, 08:56 AM
RedZ4me
RedZ4me's Avatar
well done! very nice
Old 10-26-2012, 08:58 AM
Monkey D. Luffy
Monkey D. Luffy's Avatar
Old 10-27-2012, 11:40 PM
Mike.D
Mike.D's Avatar
Thx fellas.
Old 10-28-2012, 09:44 AM
Johnson 92
Johnson 92's Avatar
C5 of the Month 6/13
Looks great!!
Old 10-28-2012, 10:22 AM
DaOtherOne
DaOtherOne's Avatar
Nice install, it looks great
Old 10-28-2012, 11:21 AM
sublime1996525
sublime1996525's Avatar
well done
Old 10-28-2012, 05:44 PM
andy82
andy82's Avatar
2017 C7 of Year Finalist
Looks great, but can you still slide your seat all the way back? I threw those brackets out because I couldn't.
Old 11-01-2012, 10:42 PM
Mike.D
Mike.D's Avatar
almost all the way back, but I don't need it back that far. Im 5 ' 11.
Old 11-01-2012, 11:40 PM
skxf430
skxf430's Avatar
How are you running your sub-belts?
Are they coming thru your seat cushion?
Old 11-01-2012, 11:45 PM
Mike.D
Mike.D's Avatar
yes, only way to do it. most of the sub harness belts are too short to go all the way under the seat and around. Besides, the subs need to be tight to your crotch. make sure you get a 6 point instead of a 5 or you may not be able to have children.
Old 11-05-2012, 02:52 AM
Wilddr805
Wilddr805's Avatar
How much is one Caravaggio Seat and does it use the heaters, air bags, and inflate for support. How comfortable are they? I wish I could sit in one here in SOuthern CA. See if it would be comfortable for a two hour drive.
Old 02-08-2013, 01:06 AM
66L72
Support Corvetteforum!
66L72's Avatar
So you have the two sub belts going through between the seat cushion and the seat back? If that's the case wouldn't it be pretty easy just to stuff them back thru into the back are after a track day?
How long are they
I looked at the sparco link but couldn't see the set up you have......which looks great by the way. How much was the harness?
Old 02-08-2013, 01:24 AM
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
I Love those seats!!! Harness bar looks great too. Did you cut the pillars or did you opt for aftermarket pre-fabricated with th eholes already cut in?
Old 02-08-2013, 01:21 PM
EX1
EX1's Avatar
Very clean install! Props!
To new mod PHOTOS -SharkBar, Caravaggio, Sparco
Old 02-08-2013, 01:46 PM
LFZ
LFZ's Avatar
Only the driver's seat??? It all looks great too.
Old 02-08-2013, 03:09 PM
ZO ZICK
ZO ZICK's Avatar
Very nice, I love the seat!
Old 02-08-2013, 04:28 PM
5280Racer
5280Racer's Avatar
Looks great.. What kind of seat is that??
Quick Reply: [Z06] new mod PHOTOS -SharkBar, Caravaggio, Sparco
