C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Tilton master and slave cylinders
Old 01-05-2013, 11:40 PM
William Atkins
William Atkins's Avatar
Default Tilton master and slave cylinders
Has anyone has experience with the Tilton master and slave cylinders for the LSX 9 Katech clutch system? Despite using the Ranger method many times my clutch would stick on the floor during track days. After my last day out the slave finally failed completely and fluid drips out of the area just under the clutch. No pressure and no way to disengage the clutch. Stock LS9 slave only lasted 8 track days. I here the Tilton master and slave fixes the problem.
Old 01-06-2013, 02:30 AM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
I have read posts on here from members that say they do fix the problem. if I were doing a clutch I would go in this direction based on the feedback I have read on here.
Old 01-06-2013, 09:29 AM
ByByBMW
Support Corvetteforum!
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Old 01-06-2013, 11:37 AM
63Corvette
63Corvette's Avatar
I have heard and seen posted that use of the "Tick" master cylinder also cures this problem.
Old 01-06-2013, 09:12 PM
Painrace
Painrace's Avatar
I have the Tick master and slave with the LS9X. It is the only way to go. When you see the stock master you will be pissed at what GM gave us. It is not an easy install. Follow the Tick instructions exactly. It is well worth your time.
Jim
Old 01-06-2013, 09:24 PM
RicK T
RicK T's Avatar
See post 5 and beyond in here:
http://forums.corvetteforum.com/c6-z...r-failure.html
Old 01-06-2013, 10:23 PM
William Atkins
Default Tilton master and slave in the LS9X
Jim
Thanks for the info. I was able to install the Tick Master this weekend with some serous effort. The unit is awesome but the problem is with the slave. I will call Katech tommorrow about their Tilton slave and get one ASAP. I hear there is a backorder.
Bill
Old 01-07-2013, 04:33 PM
BgBoost1
BgBoost1's Avatar
Jim
I have the Tick Master and Tilton Slave.....they both work well together! I would highly recommend them!
Old 01-07-2013, 06:14 PM
Painrace
Painrace's Avatar
Bill
You have to pull the torque tube to install the slave but it is worth it. Good luck and let us know how it turns out. You will be pleased.
What do you think about the GM master they gave us?
Jim
Old 01-07-2013, 06:34 PM
CanadaGrant
CanadaGrant's Avatar
Jim
Afternoon Jim. Just wondering if with the Tilton slave, you are still getting the dirty fluid after a track day or a couple of weeks driving like the crappy GM slave?
To Tilton master and slave cylinders
Quick Reply: [Z06] Tilton master and slave cylinders
