C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Heads and big cam....RWHP???
Old 01-08-2013, 03:26 PM
knockout_tx
knockout_tx's Avatar
I'm at work right now, but as soon as I can get an answer I will let you know.
I am hoping we can get all this rain behind us, and I can get out there in the next day or so to see for myself.
Old 01-08-2013, 03:31 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,682 Likes on 1,070 Posts
Well, you're going to need to wait a couple of days for that to happen.
Numbers are starting to look about right. Hopefully you got a good tuner so drivability doesn't suck (bucking, surging, idle hunting). I had horrible drivability from an inexperienced tuner with just a mild cam (Ragin' Racin' Lethal that wasn't initially installed and tuned by them).
Old 01-08-2013, 03:42 PM
6Speeder
6Speeder's Avatar
Originally Posted by avenger88
I'd say low to mid 580ish rwhp . You should really look into a halltech intake, the k&n is one of the more restrictive on the market. A halltech / beehive would be good for another 10- possibly 15hp
Actually Katech dyno'd both the halltech and the K&N, and they were statistically equal. You may be thinking of the Airaid, it was down about 10 hp from the above two.
Old 01-08-2013, 03:57 PM
knockout_tx
The original Cam was bigger than this one and I had to replace it.....it was way to much for what I wanted.
Old 01-08-2013, 04:06 PM
knockout_tx
Only for Dyno Jet
Originally Posted by justinlamanna
are they giving your results in STD or SAE ?
Old 01-08-2013, 04:07 PM
avenger88
avenger88's Avatar
Hmm idk we dyno'ed ourselves and saw the gains...
Old 01-08-2013, 04:08 PM
avenger88
avenger88's Avatar
X2 are we talking sae or std?
Old 01-08-2013, 04:56 PM
ToppThat
ToppThat's Avatar
St. Jude Donor '12
Z is at Jtran in Houston Texas( damn rain won't stop)and he has just started the tuning.
He has a Mustang Dyno so I am not sure it going to convert to Dyno Jet numbers.
The 2nd feel out run was 585 RWHP and 535 Tq
No hard pulls yet.
I did the same type of build (vette tube) Mustang At7k Thing is minutes before tear down a baseline dyno was done.At the time i had no idea how many dyno arguements it would avoid. It told me exactly what my drivetrain loss was(421 =16.5%-505) (521.4=642) and for the last 3kmi.its been trouble free. A safe tune is what i wanted so i would have something left to go further with.Good luck. Make sure you have real 1.8 cam lobe lift numbers instead of comps 1.7 specs.
Old 01-08-2013, 05:06 PM
knockout_tx
The base line on the Mustang Dyno was 399 RWHP
Old 01-08-2013, 05:07 PM
Cvette713
Cvette713's Avatar
Stock clutch? Really interested as I have pretty much the same setup...
Old 01-08-2013, 05:47 PM
RGT
RGT's Avatar
OP. Let us know the torque numbers too.
Old 01-08-2013, 05:58 PM
wolf8218
wolf8218's Avatar
Something is wrong there...
Old 01-08-2013, 06:24 PM
  #33
ToppThat
ToppThat's Avatar
St. Jude Donor '12
15 is avg. My 2 base pulls were16.5% and 18% at 7000 mj. stock
Old 01-08-2013, 07:03 PM
  #34
svtgeoff
svtgeoff's Avatar
580ish?
Old 01-08-2013, 08:32 PM
  #35
briancb1
briancb1's Avatar
You're car isn't far from PowerFab. When its all done I'd swing by and see what it puts down, compare it to mine as it seems we make equal power by your figures.
It's a dynojet.
Old 01-08-2013, 08:36 PM
  #36
knockout_tx
Kool, I will do that for sure.
Old 01-08-2013, 09:01 PM
  #37
Pb82 Ronin
Pb82 Ronin's Avatar
Does it run right? Feel strong? Don't get too wrapped up in dyno numbers as they all read differently. Plus, I've had so many customers read online that so-n-so made such-n-such HP on the same combo, but be down by 30-40 HP....only to run .5 seconds quicker on the track. Dyno's are tools to measure...and all calibrated differently.
To Heads and big cam....RWHP???
Old 01-08-2013, 11:25 PM
  #38
briancb1
briancb1's Avatar
This is 110% false information.
It's a tool to measure how cool a person is on a forum, scientifically proven by scientists......
Ha of course, but it was out of curiosity. His car seems strong!
Btw were those SAE numbers?
Old 01-08-2013, 11:45 PM
  #39
ToppThat
ToppThat's Avatar
St. Jude Donor '12
100-120 rwhp heads cam intake system and exhaust is what you get. More then that is fooling yourself. And clutch time.
Old 01-09-2013, 12:05 AM
  #40
Turbosixx
Turbosixx's Avatar
Yeah SAE or standard?
Quick Reply: [Z06] Heads and big cam....RWHP???
