C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] ANOTHER Dropped Valve in a Z06...
Old 01-20-2013, 08:08 PM
  #81
Jackal
Jackal's Avatar
I am considering selling my C5 to pay for the new motor...but there goes my track car...
Old 01-20-2013, 08:39 PM
  #82
Dirty Howie
Dirty Howie's Avatar
That would suck but I track my DD Z06
DH
Old 01-20-2013, 08:45 PM
  #83
tim414
tim414's Avatar
St. Jude Donor '12
That sucks too. Why not sit on it for a minute and do it when situation improves....that way you could take your time and do it the way you want...
Old 01-20-2013, 11:53 PM
  #84
C6z06man
C6z06man's Avatar
I'd hate to see you have to dump the track car to get the c6 back on the road. But I'd probably be debating the same thing if I were you.
Old 01-22-2013, 09:17 AM
  #85
JwT
JwT's Avatar
Originally Posted by harrydirty
Care to elaborate which motor you are referring to? Part number?
Found it in the summit catalog. Blueprint motor 580hp 560ft/lbs torque
Drop in replacement 427 $8999.00 MLL-PSLS4271CT. This is what I would replace my motor with if it went.
Old 01-22-2013, 09:26 AM
  #86
wolf8218
wolf8218's Avatar
http://www.blueprintengines.com/inde...t-engine-specs
625/565
Old 01-22-2013, 10:25 AM
  #87
Jackal
Jackal's Avatar
My only issue there is that the Z06 dry sump setup will not work on this engine. I really want to keep that intact.
Old 01-22-2013, 11:10 AM
  #88
JwT
JwT's Avatar
It will work and is a direct replacement for the Z06 dry sump oiling and 605 hp. Anyone needing info can call Blue Print direct 800-483-4263. It's just an option, I'm sure there are many others.
Old 01-22-2013, 11:14 AM
  #89
Jackal
Jackal's Avatar
oh ok, well in that case, this might be a good option, thx JWT!
Old 01-22-2013, 03:01 PM
  #90
MTIRC6Z
MTIRC6Z's Avatar
Something else to check on...I suspect it's an iron block, so around 125lbs more on the front end of your car.
Cheers, Paul.
Old 01-22-2013, 03:25 PM
  #91
Jackal
Jackal's Avatar
Nope, its an alluminum block. That is the first thing I checked!
Old 01-22-2013, 07:02 PM
  #92
Just Cruise
Just Cruise's Avatar
Good deal on that engine.
Old 01-22-2013, 07:19 PM
  #93
kennethC
8th Gear
kennethC's Avatar
That surely sounds very promising. However, do we know if this option is free of the issues of the OEMs?
Old 01-22-2013, 07:40 PM
  #94
Cozmo
Cozmo's Avatar
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Damn! I've never seen such a mess! Sorry Jackyl.
Old 01-22-2013, 07:50 PM
  #95
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Well that motor uses ls3 style heads, and intake. So that is a downgrade for performance. Also to get a 427 out of a ls3 block they maybe running a different stroke/bore setup. You definitely won't be revving that to 7k RPMs.
Old 01-17-2015, 11:00 PM
  #96
Poppa G
Poppa G's Avatar
Default Carnage
Man that just sucks!! Hope it all works out for you!!
Quick Reply: [Z06] ANOTHER Dropped Valve in a Z06...
