[Z06] Thinking of selling, help me out w/ pricing (Pictures)
So I'm contemplating selling my 2007 VR Z06. It has about 25XXX miles on the body and less than 5K on the engine. Built and Tuned by the fine gentlemen at Dallas Performance. It is a 1000hp Stage 5R build with excellent drivability for street uses. Also has Never been tracked.
The only problem is the Transmission is on the fritz, so it's in the process of being rebuilt or replaced.
~Build~
GM Performance LSX block
Callies Forged LS7 Crankshaft
Callies Forged Ultra H-beam rods
ARP2000 Rod Bolts
Wiseco dish pistons 9:6:1 CR
ARP main studs
ARP2000 cylinder head studs
New LS7 hydraulic roller lifters
Complete machine work
New cometic 6 bolt MLS head gaskets
Rectangular port LS7 billet cylinder heads with 12 degree valve design fully CNC
Titanium intake valves w? hardened tips
Inconel exhaust valves
hardened pushrod set
DP custom fuel system
2000hp rated billet fuel pump
fuelab EFI 1:1 boost ref regulator
fuelab 10 micron fuel filter
adjustable RPM activation switch
40amp weatherpack relay harness w/ fuse
2 EFI check valves
Billet fuel rails and hardware
All SS braided fuel rails
Fuel tank bulk head fittings and fuel pick up
RPS triple carbon fiber clutch kit (ZR1 slave cylinder)
Extreme duty prop shaft for high horsepower applications
extreme duty propshaft couplers for racing applications
DP 10 rib dedicated drive system
ID1000cc injectors
F1R procharger head unit
DP billet supercharger bracket
Billet procharger main bracket
billet tensioner assembly
custom DP 10 rib idler pulley w/ stand
10 rib billet harmonic balancer
10 rib billet blower pulley
10 rib gates belt billet pillow blocks
DP direct drive assembly
billet tensioner w/ swing blocks to tension alternator and PS
DD pulleys and plates
SS braided relocated PS hose and steel fittings
complete w/ gates belts and all hardware
2 Tial Q BOV- black anodized finish with weld flange
DP stainless steel lower charge tube for mounting BOV
Meziere Electric water pump
Custom catch can setup
Holley LS valve cover-powdercoat gloss black
Dewitts High Capacity Aluminum radiator with transmission cooler, cut 2' for C6 corvette
Dual 11' electric fan upgrade with adapters for radiator
DP modified Alky Control Meth injection System-includes Dual nozzle kit w/ check valve and meth filter.
I also have a billet 280(?) amp alternator on the way now.
~Build~
ARP2000 Rod Bolts
ARP main studs
2 EFI check valves
ID1000cc injectors
Awesome looking car, and I'm sure it's worth every penny.
Hard part is you're selling into a rather small group of potential buyers: guys who are into HEAVILY modded cars. I can't imagine what you have into the car... but my one suggestion would be to fix the front grill and replace the front splitter - on cars like this that stuff stands out.
