[Z06] WCCH-X vs WCCH stg 2 vs PRC
Just wondering as far as a hp/tq vs price standpoint what would people go with?
In talking with Carlos for a while I was thinking about his X heads, but with the 300ish price difference over regular WCCH heads and right about the same as PRC 265 heads... I'm just confused.
Anyone have any firsthand experience in comparing these?
Are you wanting to go with a torquer like a lot of us on here? If so you should take the decking into consideration. I have no idea what the X heads consist of but I'm personally ready to get these gm castings off the car. Not that they're necessarily flawed (who knows for sure but I'll feel better with the prcs. Plus, 3k into the prcs, then if I'm able to sell my stock heads for a grand, I'm sitting at 2k for the prcs. No brainer.
Right the PRC's would fit about the same as the WCCH-X heads cost wise, which seem to be about 400-500 more than standard WCCH heads. The heads are a different porting and some secret work to the chambers I assume... milling is optional, as on the WCCH proper heads.
I dont know much else about em except carlos says they are more efficient and let you run some more timing than WCCH heads.
As far as the cam, I don't know yet... I'm liking the dyno results of the Carlos' street menace cam, but I like the torquer as well. Haven't decided yet.
The PRCs are a non-GM design LS7 head. This means they had the option of reconfiguring the ports the way they wanted, but maintained the port locations to match intake and exhaust pieces available for the LS7. The GMPP CNC'd LS7 head has a port volume of around 270cc and the PRC 265cc port OUTFLOWS that GMPP head. This mean the PRCs have better velocity. I have not been able to get a number on the WCCH port size when ported, but the stock LS7 head is ~260cc from GM(259cc I think is the number).
The PRC heads are also fully machined and checked, hopefully eliminating the possibility of a geometry error on some/all LS7 GM heads.
Yes, I am a bit biased as I have decided to go the PRC route on my LS7. I am very happy with the choice and don't mind the few extra dollars over a reworked stock head.
The stock LS7 head is about 259 cc's I recall. The PRC 265 port is not smaller than stock I dunno how people figure that.
WCCH 2 LS7 = 1/3
Darin Morgan LS7 = 2/4
I am curious if you have the port sizes for those heads you tested. I have tried to get a size of the WCCH PP'd heads and haven't located it.
Darin's LS7 porting smokes the WCCH 2's work, flow and velocity. I've had both ports and had them flowed on the same bench (SuperFlow 600). I dunno why you would choose them and wait 4-6 weeks for heads you know arn't going to be the best they can be.
WCCH 2 LS7 = 1/3
WCCH 2 LS7 = 1/3
I posted the stock port size in my post, but I base a belief the PRC port is smaller than the other ported LS7 heads out there based on the stock 259cc size. I find it rather difficult to believe the flow numbers are coming from only 6cc of additional material removal by the various porters.
I dunno what CC my heads are honestly but they are probably in the 260's. It's also important to compare CSA's as well to get a relationship between flow and port speed. If I opened up the CSA to gain a few cfm but lost a decent margin of velocity/fps the head could actually perform worse depending on the engine setup.... But seem more attractive on paper.
Whether or not I have WCCH is irrelevant - you have Darin's. So what? Both "camps" have proven results - you like Darin's work, I like Richards. Choose to spend your money how you see fit. Keep your $3.
SS MPSTR, not to defend Brian, but nowhere did he mention that flow numbers were the only factor in making power. Just pointed out that he was able to compare a before and after product and the 'after' product flowed more AND produced more power on the dyno. Don't want to start a pissing match here, so take it for what it is. Two useless tools showing more power from the same part before and after. Each can make their own conclusion.
