C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Bucking the trend -WCCH Stage 2 heads with OEM exhaust valves
Old 02-28-2013, 04:20 PM
  #81
Dirty Howie
Dirty Howie's Avatar
Originally Posted by FNBADAZ06
That's a good question.
I would think that the additional airflow from the Stage 2 CNC porting would warrant a tune, as well as if you have a rise in compression by milling the heads.
A WCCH simple valve job, installation of bronze guides, and replacement of valve springs and valves, would NOT require a tune as they do not alter the engine's breathing capabilities..
Correct. Thats what I did. No tune car runs the same
DH
Old 02-28-2013, 04:33 PM
  #82
FNBADAZ06
FNBADAZ06's Avatar
Thanks for the definitive answer, Howie
Old 03-05-2013, 11:03 AM
  #83
FNBADAZ06
FNBADAZ06's Avatar
She's all buttoned up, and they started the preliminary 91 octane tuning last night.
Tuner says the idle at 850 RPM and the exhaust sound is to die for, with the B&B longtubes, Akrapovic titanium x-pipe and factory ZR1 mufflers.
Full 91 tuning session begins this evening at 4:00.....with full bore E85 tuning to begin right afterwards.
Finally, we'll get to see what she can do with the warm 80 degree air here in Phoenix !!!
I'll start a new thread on the final dyno numbers and the debating can commence there
Old 03-05-2013, 03:09 PM
  #84
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Congrats on getting all the work done. I'm looking forward to the results
Old 03-28-2013, 11:10 AM
  #85
zeeohh6ex
zeeohh6ex's Avatar
any updates?
Old 03-28-2013, 12:31 PM
  #86
AzDave47
AzDave47's Avatar
Thanks, Rick.
I just went a bought 10 gallons of E85 for the tuning......3.34/gallon vs. 4.04/gallon for 91 .
E85 has about 20% less energy in it than 91 E10 so the cost is about equal. Given that the E85 will give you much more performance and the engine should run cooler and cleaner, not a bad deal.
Old 03-28-2013, 04:45 PM
  #87
FNBADAZ06
FNBADAZ06's Avatar
Originally Posted by zeeohh6ex
any updates?
We are awaiting on some Russel fuel line fittings that we are going to put a fuel pressure testing port on....hopefully they arrive on Monday, then I can get bck to testing and tuning
Old 03-28-2013, 04:49 PM
  #88
FNBADAZ06
FNBADAZ06's Avatar
Yep...not bad at all
I'll see during the course of our summer how much of an inconvienence it will be with access to E85 and my driving habits and destinations. That's why I didn't go a full compression point plus on my milling...to get away with our crappy 91 pump fuel when I have too.
Old 04-17-2013, 04:21 PM
  #89
FNBADAZ06
FNBADAZ06's Avatar
UPDATE !!!!!
New Aeroquip fuel rails and Russel lines and fittings got installed, and everything buttoned back up. I had a MAF issue, specifically the IAT circuit wire, which needed a bit of work, and a torn plugwire boot on #8. The IAT wire is fixed, and I'll grab a new set of wires today or tomorrow. Then, it's back to the shop for a final inspection and another roll on the dyno.....this time with data past 5700 RPM LOL.
The idle is to die for at 850 RPM.....and the greater compression, along with the B&B's, Akrapovic titanium x-pipe, and ZR1 mufflers has done wonders for the exhaust note LOL.....
Old 04-17-2013, 07:43 PM
  #90
forg0tmypen
forg0tmypen's Avatar
Absolutely nasty! Love it!
Old 04-17-2013, 10:25 PM
  #91
SSMOKE
SSMOKE's Avatar
SICK! I want a TORQUER.
Old 04-18-2013, 01:41 AM
  #92
FNBADAZ06
FNBADAZ06's Avatar
Just as an fyi...my Torquer is the 110 LSA without the 4 degees of built in advance. In other words, the first gen Torquer
Old 04-18-2013, 10:40 AM
  #93
AzDave47
AzDave47's Avatar
Do you expect that will be better (1st gen Torquer) for our 91 octane gas or will you be going to E85, Victor?
Old 04-18-2013, 11:07 AM
  #94
FNBADAZ06
FNBADAZ06's Avatar
I'm on E85 now
The 2nd gen Torquer has the 4 degrees of advance built in to it....so it gives up a few HP on top for a few extra lbs/ft of torque down low.
For me, I bumped the compression up a bit and moved to E85, so I got all my "extra" torque back....plus I have the top end power of the original 110 LSA
I'm already putting out 500+ lbs/ft at 3600 RPM
Old 04-18-2013, 01:38 PM
  #95
azZ06Mike
azZ06Mike's Avatar
St. Jude Donor '11
Will be interested to see peak as it should stop about 6400 making power.
Old 04-18-2013, 03:54 PM
  #96
FNBADAZ06
FNBADAZ06's Avatar
I ain't telling ya what the peak is, or where, until AFTER our C-note race
Old 04-18-2013, 05:08 PM
  #97
azZ06Mike
azZ06Mike's Avatar
St. Jude Donor '11
That's fine you can tell me when you hand me the C note.
Old 04-19-2013, 10:33 AM
  #98
FNBADAZ06
FNBADAZ06's Avatar
I'll make sure to get a video of it too
Quick Reply: [Z06] Bucking the trend -WCCH Stage 2 heads with OEM exhaust valves
