[Z06] need lightweight wheels for my c6 zo6
KaNDriZO6
hello every body
i have c6 zo6 i need light weight wheels between 15 - 18 lbs 4 wheels my tire rear Hoosier 315-30-18 rear size i think 18x10.5 is good
what i choice ? rear 02 zo6 21 lbs there's less that ?
thanks
thanks
z51vett
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Go weld.
I love ForgeLine's and they make light wheels for sure, but for drag racing and the weight you are looking for you are not going to beat a Weld.
They make the RTS series now in 15, 16, 17, and 18" diameters for the cars. I did set set for a Camaro in 17x4.5 fronts and 17x10 rears. I think the rear wheels were 14 or 15lbs each if I remember right. Fronts were 10 or 11
KaNDriZO6
Go weld.
know i see best wheels weight and cheap and fit rear 02 zo6 18x10.5 21lbs
front stock wheels 18x9.5 22lbs 275/35/18 if i change 235/35/18 i thing good weight with 18x8
I do not know what to do i pay to much money for remove weights i buy four rotors Coleman 32lbs and driveshaft carbon pfadt 4lbs and change seats and change the clutch monster 44lbs to McLeod 30lbs know need only the big problem the wheels I do not care about the shape I want to just remove the weight
