C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Took my N/A build to the next level-13:8 compression +E85
Old 03-04-2013, 08:14 PM
EX1
EX1's Avatar
Default Took my N/A build to the next level-13:8 compression +E85
My previous modifications
-Heads milled .040
-Widow cam
-FAST 102
-FAST 85# injectors and rails
-NW 102 throttle body
-Halltech CF112
-LG 1 7/8 longtubes
-LG x-pipe no cats
-Akrapovic exhaust
-100 dry shot
What changed
-Heads-WCCH stage 2 porting and angle milled .130 for approx 13.8 compression (XR head profile)
-Walbro 450lph fuel pump with Aeromotive external filter
-ARP head studs
-50 dry shot
This first graph shows my old pulls compared to this new setup. Solid gains throughout the power band. Note that I actually cut my nitrous in HALF and still gained a large amount of power in the midrange (more than the peak hp difference). All of these numbers are uncorrected. This is what the car actually made, no correction factors here Props to MyHardtop (Carlos) from Vette-Air on the tuning. WCCH also said that my stock guides were trashed, just fyi.
BLUE = Old N/A
RED = Old nitrous 100 shot
GREEN = New N/A
PURPLE = New nitrous 50 shot
Here is another graph of just the new setup by itself.
Old 03-04-2013, 08:20 PM
DaOtherOne
DaOtherOne's Avatar
Great numbers!
How many miles on the stock guides?
Old 03-04-2013, 08:23 PM
EX1
EX1's Avatar
Originally Posted by DaOtherOne
Great numbers!
My stock guides had 16k miles.
Old 03-04-2013, 08:25 PM
blacktavert
blacktavert's Avatar
Nice work!
I have always paid attention to your setup as I am planning on going with a similar build with E85, but less compression
Was the stock pump not able to keep up with the extra flow needed for E85? We're you running E85 before the new upgrades?
Old 03-04-2013, 08:27 PM
FSTFRC
FSTFRC's Avatar
Impressive! Engine looks good too. Did you do the mechanical work?
Old 03-04-2013, 08:29 PM
619grappler
619grappler's Avatar
Awesome. What size cam you running?
Old 03-04-2013, 08:51 PM
EX1
EX1's Avatar
Originally Posted by blacktavert
Nice work!
Thank you! I was not running E85 before the upgrades. Just pump 91. The stock pump cannot keep up with the demands of ethanol.
Appreciate that. HPP in Lewsiville, TX turned the wrenches this time.
It is the first gen Widow cam from Vette-Air. I'm not sure Carlos would appreciate me posting up the exact specs.
Old 03-04-2013, 09:03 PM
NachosZO6
NachosZO6's Avatar
Awesome numbers. How scary is that thing on the street? Bet it's hella fun regardless.
Old 03-04-2013, 09:11 PM
C6z06man
C6z06man's Avatar
Great numbers. Any clue what timing numbers you are using up top with the nitrous? Maybe Calos can chime in??
Old 03-04-2013, 10:24 PM
EX1
EX1's Avatar
As long as the car is rolling, the NT05Rs are doing pretty well and make the car managable.
I honestly can't recall. He mentioned the other day but like before, I asked him to tone it down. I don't mind leaving 10-15 on the table.
Old 03-04-2013, 10:31 PM
C6z06man
C6z06man's Avatar
I'm with you. No sense in running it on the knock threshold for a few HP.
Old 03-05-2013, 04:00 AM
0Myhardtop
Former Vendor
Myhardtop's Avatar
Yep!
Timing is at 23* down low, then 20* around torque peak and up to 22* out. AFR is in the 12.1 to 12.3 range on the punch, then 12.0 to 12.2 at torque peak and 12.3 to 12.4 out.
His car actually had more in it 26* down low, 22* TQ peak and 24* out with slightly leaner AFR across the board, but I prefer leaving power on the table for safety. Heck, I even programmed it to add fuel and pull out 3 more degrees of timing if IAT's and ECT temps get out whack. Believe me, you will not feel 10-15 hp.
Hope this helps.
Thanks,
Carlos
Old 03-05-2013, 09:54 AM
azZ06Mike
azZ06Mike's Avatar
St. Jude Donor '11
Very nice numbers!
Old 03-05-2013, 11:02 AM
gtodoug
gtodoug's Avatar
that is sick. I would do this in a heartbeat if I felt comfortable that I could get e 85 anywhere around here where I live in south florida. That this has got to rock out with that type of power and tq.
Old 03-05-2013, 11:19 AM
FNBADAZ06
FNBADAZ06's Avatar
Bad ***, bud !!!!
My E85 package hit's the dyno rollers this afternoon....but I'm only packing 11.6 on a .030.
Old 03-05-2013, 11:39 AM
LEAVINU
LEAVINU's Avatar
Can you talk about the dry plumbing, setup, etc?
Very impressive results!
Old 03-05-2013, 12:02 PM
BgBoost1
BgBoost1's Avatar
Great Numbers. I have been on E85 for over 2 years now.....I LOVE IT!!!!
To Took my N/A build to the next level-13:8 compression +E85
Old 03-05-2013, 12:06 PM
EX1
EX1's Avatar
thanks everyone
Old 03-05-2013, 12:11 PM
EX1
EX1's Avatar
Some guys just buy E85 by the 55gal. drum for $~130 and keep it in there garage. You always have that option
Originally Posted by FNBADAZ06
Bad ***, bud !!!!
Do you plan on upping the compression to take full advantage of the E85?
What is your setup?
Thanks. I am using a single solenoid mounted underneath the intake shroud. The line is then ran into the bottom of the filter. I have a microswitch that makes the ECU jump to a different set of timing tables when the nitrous is armed and the pedal is down. I also have a window switch to keep the nitrous going from 3500rpm-6500rpm.
Old 03-05-2013, 12:20 PM
azZ06Mike
azZ06Mike's Avatar
St. Jude Donor '11
I have my H/C Z06 on E85 and wish i would have increased the compression for more power.
Quick Reply: [Z06] Took my N/A build to the next level-13:8 compression +E85
